We value your privacy.
>As soon as I shaped the outside of this piece of wood and stopped the lathe, I knew what I had -- Humpty Dumpty as reassembled by a committee. Size. 18 1/2 inches wide and 8 inches deep. Wood: Sugar Maple burl with lots of swirl and almost too many bark inclusions. (The amount of CA glue to harden it before sanding was frightening.)
>Awesome piece of wood with a beautiful execution. At 18" I'll bet this causes a lot of "WOW"'s. I also like the way the rim has a slight inward slope.
>It is a beautiful bowl. Have you ever tried firming up wood such as this with the thinned epoxy method? On a couple of occasions I have used that method, thinning epoxy with alcohol to stabilize some porous/punky wood. This is a beauty of a bowl!!!
>Stunningly elegant in its simplicity. A bowl that will stand the test time. The lift from the bottom elevates the bowl and gives it a floating quality.
>Thanks for the comments, everyone. Allen, there is a flat spot on the bottom, so it is stable. I have been going to make a "round" one for some time, but have not got around to it. Originally, I procrastinated because I though this shape was unstable enough without making the bottom round. But I have found that all the bowls of this shape have a serious attitude when you try to knock them over. The right themselves in no uncertain terms. I still have to figure that out because you would think this shape is inherently unstable -- ever try to stand an egg on end? And I have not left any extra weight in the bottom. It is the same thickness from the rim right to the foot. Mike, I have tried epoxy and like it. But the gallon of epoxy I bought (to do some boat work, which is still not done) gelled some time ago and I had a new 16 oz bottle of CA. Not much of that left -- should have bought epoxy. I always thinned the epoxy with acetone. I will have to try the alcohol.
I agree -- it was surprising to read how large it is -- that's some nice hunk of burl. I like the simple shape (not easily done!) which gives it lift, which makes it look light. Anyone on this forum would be proud to post that bowl, or better yet, to own it!
>You've got a winner there, Bill! I love bark inclusions and often wish I could find more wood with them. I cannot tell if there is a tiny bead at the rim? (Old eyes, here) I also could not believe it when I saw the size of the piece. Great work!
