Barracuda II ??
Barracuda II ??
Barracuda II ??
Thad
>I read Mike's review of the barracuda II chuck from PSI that was posted Aug 18, and I am curious if anyone else has anything to say about it as the package PSI is offerring until Nov seems appealing.
~ Thad
Re: Barracuda II ??
Re: Barracuda II ??
Russ Fairfield
>Chuck are one place where you get what you pay for. This is not a Oneway Talon, or a Vicmarc chuck. Don't expect to get the same steel, fit and finish as the more expensive chucks at these prices. Testing them with a file tells me that they are made from a softer steel, rather than an alloy steel as used in the more expensive chucks. That means they will wear out quicker, and my observation of a couple of them is that they do. Whether this is important or not depends on how much woodturning you will do. A high volume woodturner would be better off spending the extra money for a better quality chuck. The casual hobbiest woodturner will never know the difference.
Other than that, they appear to be well made, with acceptable machining and accuracy.
