Powermatic 2035B outboard attachment
>I seem to remember hearing that Powermatic had an outboard attachment offered for the 2035B that included a riser for the tailstock and Tool rest. I tried searching thier website last night but I was tired and only found one vague reference. Then my computer locked up so I gave up for the night. Anyone know if this is offered or did I dream it up. I can drill holes in my legs and mount my bed extension lower.
Re: Powermatic 2035B outboard attachment
Charlie Anderson
>I've not heard of it. When you buy the 18" extension, you get a riser for the banjo for installing the extension in the lower position with the 38" swing.
David Galloway
>John, I remember that being touted as well, which is much better than trying to dance with the freestanding tool rest. I recommend that you call Nick Cook 770- 421-1212 as he seems to know most everything about the beast.
Having an original 3520, I resorted to mounting a VicMarc outboard tool rest on the end of my leg. It has worked nicely, allowing me the illusion of having my coveted VB.
David
The previous post should be deleted/edited.
Craig Daymon
>It is very bad internet practice to post phone numbers in messages, ESPECIALLY when it is not your number. It is a violations of the persons right to privacy. That number is now available for anyone, not just John. Send it to John in an e-mail if you want, but DON'T post it in a message.
-Craig
P.S. John, if you check Olsolnik Machinery, they have a pretty complete listing of all the accessories for the 3520.
Ed Kelle
>I've got it. Comes with 6" toolrest riser. New B legs have mounting holes for either flush, or lower mounting. Lower can be done on either leg. Flush is one side, tapped for the bolts. on the other holes are drilled out for thru bolts for adding another full bed extension. Of course I put the legs on the wrong sides to do the flush mount, I don't want the headstock weight on the extension, so I'm not going to remount the headstock unless absolutely necessary. Got mine at Osolnik
>Thanks Ed. I actually have my bed extension on the motor end. Most of the time the motor (not the headstock) sits over the extension. That way it doesn't take up as much space in the shop.
Re: The previous post should be deleted/edited.
>I agree. I've got Nick's number anyway. I buy my wine stopper corks from him.
Re: Don't worry about it...
Russ Fairfield
>Nick has his telephone number, fax number, e-mail address, and street address listed on the front page of his website. You can't get any more public than that.
Chris K in MD
>Did I hear corerctly that some people are mounting this to their 3520A legs? I assume that they are drilling and tapping? I am really interested in this if I understand it correctly.
Here is a link to the kit with a picture.
http://www.osolnikmachinery.com/index.asp?PageAction=VIEWPROD&ProdID=79
Work on a Jet JWL-1642?. Q: PM3520 dims
Dominic Greco
>I just took a look at the extension bed and it looks like it would fit on my Jet JWL-1642. Does anyone know if the bed of the Powermatic and Jet share the same critical dimensions? If so, then this is a real no brainer. For $300 you get the ability to turn large(er) bowls. I think that the list price for just the bed extension for the JWL-1642 is $300.
Can one of you Powermatic 3520B owners out there measure the width of the bed, the gap between the ways, and the thickness of the bed, on their lathe? (The more dimensions the better!)
See ya around,
Dominic
I have an "A" and mounting holes look the same.
Craig Daymon
>Based on the illustration, it looks like it will mount to the 3520A or B. I have the same 3 (threaded) hole patterns on both the legs of my 3520A.
I didn't realize this came with an extender for the tool rest. I haven't turned anything 20" yet, but I'm tempted to get this rig so I can jump straight up to 30" (or whatever the new max comes to).
-Craig
Then give a link to Nick's site.
Craig Daymon
>It's still not appropriate to put up his number. That's something only Nick has the right to do. If the info is on his page, post a link to the page.
-Craig
Bob Fawcett
>John,
I have the extension kit. It does not come with a riser for the tailstock. It does come with a tool rest extension so you can use it for bowls. Bolts to the legs which on the 3520B are predrilled and tapped to accept the extension. Not sure about the 3520A.
You got a lot of answers but I did not see anyone address the tailstock riser.
Charlie Anderson
>And therein lies the shortcoming of the extension.
Re: I have an "A" and mounting holes look the same
>The A only has holes on the top for the bed extension. I was told that the holes are the same just lower on the leg. I plan to drill them myself but may have to do some grinding to get that portion of the leg flat so the bed extension will sit accurately.
>The extension is long enough to let you do some platters and narrow bowls with the tailstock if it had a riser block. I guess I'll have to plan on building one of those. Unfortunately the tool rest extension is the easy part to build. The tailstock riser will require some machining of the top and bottom surfaces that I can't do myself. I could build it out of wood to get me by for the few times I would use it.
OK, I guess I have an A+?
Craig Daymon
>I just went down and took some measurements for Dominic. There are 2 sets of 3 holes on each end of the lathe. One is on the end of the bed, where adding the 18" would simply extend the bed, and the other set is on the legs, which would result in an additional 18" of swing. (The holes in the leg are 9" below the holes in the bed end.) I can't imagine the extension is meant to mount any lower. Besides, the spread of the legs would not make that feasible. I think I can resign myself to a 38" max bowl.
-Craig
P.S. Bolt holes are 3/8"x16tpi and the top 2 in the triangle are 4" apart and the bottom one in the triangle is 4.25" down from the other 2. (Of course, I may be off on this a little, but that's what I came up with.) The 3520 bed is 8" wide with 2.5" between the ways. The ways are 9/16" thick. (I think that's 9/16", but it might be 3/4". Maybe someone can confirm.)
Thanks Russ!
David Galloway
>I am amazed at the tone of emails here responding to my post. Russ is exactly correct. I was trying to be helpful. Next time, I'll post his website. It's his business for God's sake. Get a life.
Re: OK, I guess I have an A+?
Chris K in MD
>Craig,
I guess its entirely possible that you have some 3520B legs on your 3520A. I noted on the 3520b that they have bosses on the inside of the leg I assume to give the bolts more bite. Are yours the same? Can you take a picture or two?
It's really simple. Please read.
Craig Daymon
>OK, so it is Nick's work phone. Fine. It still shouldn't be posted by you to a message board. Software is available to search such boards as this and find phone numbers and e-mails that are then used by a wide variety of scammers to defraud individuals. I suspect Nick is not foolish enough to be taken in by such scams, but it still does not mean he wants to get calls from people that have no interest in his products/services.
If you link to his site, those interested can easily get what they need and those with alternative motives won't bother following the link.
It's also just plain good internet practice/etiquette.
I don't know what the e-mails you received where like, but the comments made here regarding your post were relative to how to better post the information and why there is a problem with posting phone numbers in messages. Also why the original post should not be left as it was posted.
-Craig
Re: It's really simple. Please read.
David Galloway
>This will be my last post regarding this. Nick has given me permission to post his website and/or number. And so I have. I am aware of internet protocol. Again, I was trying to be helpful.
I find your continued attempts to "school" me more than irritating and pedantic at best. I would be more than happy for my entry to be expunged and sent to the bowels of the internet. Fini.
I'll try and take some pics tonight.
Craig Daymon
Pricing. 18" $209, plus toolrest extension $299
Craig Daymon
>Looks like just the bed extension is $209 from Osolnik. With the toolrest extension it is $299. (To both you need to add about $80 for shipping...to the east coast.) Think the toolrest extension is worth another $90 or would it be easy to fabricate one?
-Craig
Looks like it is an A+
Craig Daymon
>Chris,
I took a look at the manual PDFs for the A and B and the legs on mine are like the B, not like the ones shown on the cover of the manual for the A. Unfortunately, I didn't get the tool rack, the improved banjo, digital speed read out or indexing. It must be because I bought one of the A closeouts.
Anyway, here's the pics.
-Craig
2nd pic
Craig Daymon
