Shop built 3 Point & Half Round Tools
Dominic Greco in Richboro PA
>Hello Everyone,
I was very lucky and managed to squeeze in some shop time this weekend. One project that has been in the works for some time now was making a 3 point tool.
The "need" for this tool can be traced back to when I took William Duffield's shop built 3 point tool for a test drive at Bill Grumbine's BBQ this past summer. Once I discovered how easy it was to roll a bead with this, I knew I would love to have one of these tools in my arsenal. Stacey Hager's article in last year's "American Woodturner" (Fall 2005, Vol 20, No 3) gave me most of the details I needed. With some more help from William, John Lucas, and another American Woodturner article by Stacey Hager (Spring 2005, Vol 20, No.1), I learned how to use a compression nut and a specially cut handle to act like a collet system. In essence, I could remove the tool rod at any time and replace it with another. While I don't plan on switching around that much, I like having the ability to remove the tool rod when it came time to grind the profile. Who knows, I may end up grinding another profile on the opposite end. I figure it's nice to have that option.
With the reciept of a couple drill rod blanks graciously sent to me by Steve Antonucci, some assorted brass compression nuts from Lowes, (1) cherry and (1) walnut tool handle blank, I was ready to roll.
Steve me a 1/2" and 3/8" dia drill rods (and some small ones I plan on using later on for hollowing tools). At first I was going to make two 3 point tools (one 1/2" dia and one 3/8"). But I came across another article written by Stacey Hager in this month's American Woodturner. The article contained complete and detailed instructions for making a "Half-round tool". If you've seen the "Skewchigouge" as featured in Packard Woodworks catalog, then you have sort of an idea what this looks like. After seeing this tool advertised, I got curious about how it handled. So this was a good opportunity to make one and see how I liked it. I decided to use the 1/2" diameter rod for a 3 point tool, and the 3/8" diameter rod for a half-round tool.
I modeled the shape of the handle off of my Sorby Sorby 1/2" skew. The 1/2" diameter tool rod meant that the 3 point tool was going to have with some heft to it. So to give me a bit more control, I decided to make the cherry tool handle a bit wider at the front. I have somewhat large hands, so this gave me a very comfortable grip. The half round tool's handle was sized exactly the same as my skew and fits in my hand rather comfortably.
I used calipers and judicious application of a parting tool to size the end of the tool handles to perfectly fit the compression nuts. I then threaded them with the appropriate die. While holding the handles in the wooden jaws of my bench vise, I used a dovetail saw to cut the two perpendicular cuts in the "collet" area at the ferrule. These cuts allow the jaws to flex, and when the ferrule it tightened, grip onto the tool rod. After making sure the compression nut fit perfectly, the threaded area got a coating of thin super glue to help minimize the damage caused by threading and unthreading the ferrules.
Since I went and used some pretty nice wood for the handles, I prettied them up a bit. Each handle got decorated with some burned rings as well as my signature.
Grinding the profiles was a snap. The articles gave me all the information I needed. William's tip on using the hex nuts to establish the angle for the 3 point tool came in very handy.
I finished up the tool handles yesterday and gave them a coat of danish oil so they wouldn't absorb too much dirt. I ground the profiles this afternoon and took both of the tools for a test drive on a pepper mill body turned from some very hard and dry Osage Orange. I was extremely pleased with ease that I could roll a bead with my new 3 point tool. And if you've messed with rock hard Osage before, you know that rolling a clean looking bead in this wood in no easy feat. I tried the half round tool to modify the profile at the coves. This tool took some getting used to. But overall I was pleased with the surface it left.
See ya around,
My ugly mug
Dominic
Re: Shop built 3 Point & Half Round Tools
Pic #2
Whoops! Pic #2
>Here's a shot of the grind profiles.
Pic# 3
>Here you can see the fingernail-like grind profile on the half round tool. The main profile was ground by holding the rod against an 8" dia grinding wheel. So the cut has a 4" radius. The small bevel at the tip is at 45 deg, while the sides are at approx 80 deg. The small bevel and sides were ground with the help of the wolverine jig's fingernail profile tool.
Pic#4
>Here is a close look at the ferrules. You can see the cuts for the collet as well as the way that they grip the tool rod.
Jorge Castaneda
>Hi Dominic,
They look good, let us know how they perform.
Where did you find the collets?
Thanks
Jorge
Gil Jones
>Fine work, Dominic.
Thanks for the "jump start" :)
Colin Spencer
>Dominic, You may find that you like the point tool even more if you make a smaller one. I have 1/2", 3/8" and 1/4" and find that I rarely use the 1/2" one and the 3/8" is the most commonly used. Certainly John Berkley (of thread cutting fame in the UK) only uses the 3/8" according to his article in this months Woodturning. My point tools all have a bit longer grind to them and I use them as a skew as well. Maybe turn your 1/2" one round in the handle and grind a longer piece on it an see which you prefer.I just sharpen mine now with a diamond file and they work well. I hope this is of use. Colin
George Van
>Thanks for taking the time to post this tutorial Dominic, now I will finally dig out those HSS rounds I ordered and make my own.
Steven Antonucci
Hey Dom- My first thoughts were like Colin's
steve antonucci
>I'm sure that you've already found out that any angle will cut, but I have a much more acute angle on the point tool I made too. Mine is only 1/4", but it's great for small beads and detail.
Nice to see you putting the steel to good use...
Steve
Hi Jorge
Dominic Greco
>Jorge,
The brass compression nuts came from Lowes (but I'm sure Home Depot has them as well). Check out the Stacey Hager's "Cove Tool" article I mention in my original post for more on the "collets".
See ya around,
Dominic
HI Dom, Thanks!
Jorge Castaneda
Re: Shop built 3 Point & Half Round Tools *LINK*
Darrell Feltmate
>Dominic
Those look great. I made my three point out of 3/8" HSS and my skewchigouge out of 1/4" like my round skew. I have some pictures and info on the web site. They are really handy for spindle work and I used the three point to bead the outside of an ash bowl with no problems.
Around the Woods
