We value your privacy.
>Does anyone know of any good turning books? I just got an old delta lathe and some tools, sharpenend them up, and it seems like I can't get a smooth cut. I noticed my tools were "sticking" on the beat up tool rest, so I drawfiled it, and buffed it smooth. It's alot better, but I still need some help. I thought you could smooth and straighten a cylinder with a skew, but it seems to keep snagging. it's really sharp (I'm a professional cabinetmaker, and it's sharp enough to chop DT's with) how does the process work? do you lead the cut with the heel or toe of the skew? do you angle the skew so only the leading edge is cutting? or do you use the whole bevel to rub against? Thanks for the help! I usually only post on hand tools, but I figured it's time to broaden my horizons ;-)
>Would suggest "Woodturning A Foundation Course" by Keith Rowley avaliable at Barnes & Noble or many places on line. There is also a VHS tape available by the same title. Have suggested this material to many new turners and after thrie use of same all have been appreciative. The skew question; in smoothing use center of skew much like a plane but make sure bevel is rubbing wood prior to bringing cutting edge in contact with wood. You corrected the tool grab problem, with the rest, exactly right!
>Gary I can't recommend a good book because all I have are more advanced. A video would probably be better because it's necessary to watch how the tool is used. Going to a turning club or watching another turner is even better.
A spindle roughing gouge is easier to use to round a cylinder but the skew should work. You need to angle the skew so the cutting edge is about 45 degrees to the direction of travel. Most turners in the US use the heal down but you can use the toe down also. What matters is keeping the bevel of the tool rubbing and cutting below the center point . If you get the cut above the center point of the cutting edge it will tend to pull the skew into the wood and you will get a catch when the point is pulled into the wood. This happens toe up or toe down. You can control where the wood is cutting on the skew by twisting the handle slightly in your grip. To make sure your on the bevel put the tool on the wood with the handle low. Then very slowly lift the handle until the tool starts to cut. If you want a deeper cut lift the handle more.
>If you are determined to master the skew, get Alan Lacer's videos on using it (The Skew: The Dark Side the Light Side" and "Son of Skew") They are excellent. You are starting out with the tool that many turners avoid like the plaque, just because they have heard that it is difficult! It's really not that bad. A good way to learn is to use a safety center which allows the piece to slip if you get the beginnings of a catch. Those centers are a great way for a beginner to learn tool presentation and to experiment without scaring yourself to death! LOL
>I've been turning a little under a year now and I've been told that if both the "heel" and "toe" of the skew are in contact with the wood, you're asking for trouble.
Books and especially video will be helpful, but I feel until you get some good hands on with an experieced turner your progress will be slow and maybe painful.
>Once you get the tool control mastered, you might want to put an add in the paper to sell all those "flatwork" tools -- this stuff is soooo much fun ! On a more serious note, welcome aboard; I hope you enjoy the helpful tone of this forum -- great bunch of people.
I'd echo what others have posted, especially the part about finding a local club for hands-on help, and trying videos/DVD's whenever possible, so you can both see and hear the tool cutting properly. Richard Raffan'd videos and books are very good, with excellent photography, and Keith Rowley's book is a classic for mastering tool control. Also check out Alan Lacer's DVD's on using the skew.
I also want to stress what John pointed out -- orient the tool so that the curl comes off on the lower 1/3 to 1/2 of the tool, and catches will become rare, so long as the bevel is in contact with the wood. Its worth playing around with different angles and such while turning the spindle by hand, with motor off, to see the curl and/or catch develop. Most people strive for a cutting angle (edge to oncoming wood fibers) of about 45 degrees, and like planes or scrapers, it sometimes matters which direction you cut.
If you have older tools with square corners, you can also round the corners at the short point (heel) of the skew, but that will both slide across the rest better, and skid off during a catch better, too. Many people leave the long point (toe) with square corners, so when slicing across end grain with the long point down, you have a flat reference point.
>I'm in waterloo, closer to rochester, right in the heart of the fingerlakes. I know of a good club here, Rochester Woodworkers society, and they have a Group for turning. I think I'll look into it. Thanks everyone for the help, I'm sure I'll be posting again...
There is a gold mine of information in the articles online here. If I might be so bold, and I am, you might like to come on over to my site and see some of the stuff there also. We all try to share how to turn. It is one of the things that makes this so much fun.
