We value your privacy.
>I have a Nova DVR and have come across a problem with the spindle threads. I have had the DVR for almost 2 years. I had a very difficult time taking off my talon chuck and when I did, I noticed a lot of metal coming off the spindle threads. The threads closest to the head stock all have had the crown of the thread removed. The three threads closest to the head stock have all had their crowns removed and they are now "flat" to the point where they are over a mm wide now. The threads at the end of the spindle are fine. The roots of all threads appear to be fine, only the crowns have been damaged. Have cleaned both the talon chuck and the Nova 3" faceplate and they are both stiff on the spindle after about two rotations. Am concerned that the spindle will continue to lose metal to the point where the threads no longer provide their function. Any idea as to what happened and how to prevent any further damage? Anyone else with DVRs experience this?
>Bill, do you not use set screws even when turning in reverse? That is the only time I use them and I hate it because I am afraid I will forget about them when removing the chuck. I have once and marked the spindle before I remembered. I have wondered if they are really necessary if I tighten the chuck or faceplate down with the wrench?
I never use them, once in awhile I see the chuck or face plate loosen up but I simply stop and tighten up a bit. I use 1 1/4" plumbing poly washers from ace hardware and a firm hand tighening has always worked. Think I read it here enons ago.... works for me.
>Sounds like a set screw to me. I can see it happening.
Now then, Bill, I use the set screws. I was afraid if I ever saw the faceplate loosen, by then it would be too late, and I couldn't shut it down fast enough to keep my piece on the lathe... I could just see it bouncing across the floor.
Do you do any reverse turning? Curious about this subject. Do I need them or not--so to speak. :o)???
I never use them and use reverse turning and sanding on all bowls however, I forgot a step. I have learned that the poly washer soon mares thus preventing a good seat once the chuck is removed and set again. I now CA glue a stainless steel washer to the poly washer on the chuck side and use the chuck to set them, they last forever. I just use firm hand to tighten but it sometimes will take a tool to remove the chuck on small turnings as the poly washer compresses.
>Set screws seem to be the culprit. The talon chuck goes on quite nicely now with the set screw removed. The face plate is still a bit tight at the start. Thanks for the heads up.
>Just out of curiousity, did your DVR come with face plate wrench when you purchased it? Mine certainly didn't and I have a heck of a time trying to get the face plate off after I turn a piece. A wrench would certainly help.
>The set-screws are there for the Oneway lathes which have a groove behind the threads for the set screw to tighted into. They do have a useful purpose to prevent the chuck from coming off when running in revense. More inportant, they keep the chuck or faceplate on the lathe when decellerating a large heavy piece of wood, and the lathe stops and the wood wants to keep on spinning. Without the set-screws, about all you can do is get out of the way.
Using the set-screws will also tighten everything up and can stop or reduce vibration when it is a problem.
Using a piece of plastic between the shoulder on the spindle and the chuck does nothing to prevent vibration, and can encourage vibration because it is not a ridgid joint. For that reason, it is best to not use them. If you do, and you have a vibration problem, remove the plastic and it will probably go away.
Other lathe manufacturers have started to add the groove behind the spindle threads and advertising that they though of it. Nova is not one of them. If you want the benefits of the set-screws use nylon screws. They won't tear up the spindle threads.
>The DVR has a groove at the base of the spindle thread and a set screw on the provided face plate into which it fits. The spindle, however, doesn't appear to be hardened because I chewed up my threads with the set screw. Like the idea about nylon set screws, however.
My faceplate and chuck get on so tight, having it come off when reversing turning when sanding seems unlikely. I need quite a bit of leverage to get either of them off.
>Yes it does. But I have to secure the spindle shaft to prevent it from turning. I end up using the knock-out bar through the holes in the handle to "lock" it in place before I can use anything on the groove in the face plate. A wrench just seems a lot easier, if they are available.
>All good points Russ. I should have mentioned that I am more of a production turner having 4 chucks and 12 face plates in use most of the time so the poly washer works well for me.
Doug, the oneway face plates come with a 3/8" hole and rod for easy removale and the 3" have 6 screw holes for better security. I aviod using the nova plates when possible.
>I try not to use washers between my chuck and lathe if possible. The only times I've had the chuck come loose was with a washer inbetween. I haven't noticed vibration problems when using the plastic washers but then I rarely turn long things on a faceplate which is where this would be most noticeable. I do have one chuck and faceplate that won't screw on all the way so I have to use 2 washers on that one. I try to make sure it's really snug when using the washers.
I use a technique John Jordan showed at a demo once. I put the chuck on finger tight. Then lock the spindle and give the chuck a good push with the removeall bar. This locks it firmly and when you have to remove the chuck it only takes the same pressure that you installed it with to remove it.
I also use a very thin layer of air tool oil on the threads to lube the spindle. This aids in keeping the chuck from locking up on the spindle. I wipe some on and then do my best to wipe it all off. It works great. I think Steven Russel was the one who gave us that tip.
>I have had a DVR for several years now and the chucks and face plates go on and off freely. I do not use washers except with a vacuum chuck and there I use O ring to seal it.
What I find is that if i screw them on just "snug" they come stay on as they should. I usually hold the hand wheel with one hand and screw the chuck on with the other. I find that if I screw them on with the shaft locked and give it a little too much snap at the end the chuck locks on tightly. If I find the chuck is reluctant to come off I put the chuck wrench in the hole and with one hand holding it firmly down against the chuck, I slap that hand with the other and it usually loosens the chuck.
I know you should not use the indexing pin for a shaft lock, but I do and as long as I am gentle and not using hammers and pry bars, I have seen no damage.
I have had case where I spun the chuck on way to tight and really snapped it into place and the insert in the chuck lock onto the shaft tighter than chuck was lock on to the insert. When I unscrewed the chuck, the insert stayed on the shaft. Periodically I have to tighten the set screw in the chuck that keep it locked to the insert.
I don't have a wrench, but I may get one. I do have a set of Channel lock pliers that work quite nicely for this and I set them in place and use the technique of slapping the one hand with the other. When things are really tough, I lock the hand wheel with the knock out bar.
Having babbled on for so long, I would get to my main suggestion. You need to get a proper "die" for your threads and clean them up. or file the carefully. Your face plates and chucks should screw on smoothly and freely and lock up against the shoulder on the lathe. Contact Tim Giest, Technatool's US Rep if you need help. They would probably re mill the shaft for you, but you would have to send the head back.
Incidentally, if you turn the lathe on in reverse and the chuck is not locked in place, it just unscrews itself and falls off. It did not fly around the shop. DAMHIKT I wonder if it would if it were running full speed when you put enough pressure on to unscrew it?
>I don't use set screws on any of my lathes including the DVR. I have seen too many torn up threads because of them. Just tighten your chuck and faceplate and go. Reverse is for slow speed only, in my book. The Vicmarc lathes has a locking collar for faceplates and chucks. Again I don't use it. I took mine off because I didn't like getting my hand smacked on the hand wheel. GT
>What is your idea of slow speed? I sometimes turn in reverse when I have a piece with particularly nasty grain/tearout problems. It usually solves the problem quite nicely. Don't think I have cranked it above about 750 in reverse though.
>Carole, you are an experienced user. All bets are off for you. Slow speed is anything between 100-700 approx. rpm and that is debatable. I was thinking safety. If you must use Reverse be sure it is back to forward(all lathes). Don Derry turns in reverse, you ought to see him cinch down the chucks hard and use no set screws. To each his own. I will sand in reverse sometimes very carefully. GT
>LOL! Don't know about experienced - dumb maybe! My Nova will hardly let me forget it is in reverse - it beeps at me and has what seems an interminable delay before it begins to spin when in reverse. Drives me nuts sometimes. :)
