Re: Barbara Gill, Velvit oil
Barbara Gill, Remlik VA
>Hi Mike. I have developed my own procedure for using the oil on wood like Cottonwood. I don't mind at all sharing it with you.
Cottonwood is very absorbent. I keep brushing on oil inside and out for about 30 min. (I come and go about every 10 min.) I then wipe off the extra until the surface appears to be dry. Since the first coat has penetrated the wood so much, I usually give the piece at least a week or more for that first coat to cure. Then I lightly sand with 600 grit with the grain and put on a second coat. This should not penetrate or if it does it shouldn't be much because the first coat went so deep. I keep repeating the sand and coat until I get the look I want. After I reach that point I put the item aside until the smell is gone. I found out the hard way that if you buff too soon with woods that absorb a lot of oil you seal the surface and it will take forever to loose the smell.
With harder wood like cherry I let the first coat dry overnight at least, sand with 600 grit and apply second coat. I wait about a week to buff.
You can wet sand if you want but I don't usually because it is messy. Sanding with 600 between coats does the same thing for me.
