Angle drill
Angle drill
Angle drill
Jim Rutten
>Are there any advantages to having an angle drill for sanding as opposed to a regular drill other than being able to get to more places?Thanks for your replies.
Re: Angle drill
Re: Angle drill
Leslie S
>I have a touch of Carpal Tunnel and smallish hands, the angle sander is easier on my wrists and hands.
Re: Angle drill
Re: Angle drill
Leppikallio
>Angle drill is much easier to control.
I just hold brand new Makita angle drill in my hand today and now I have one more target for that lottery money I just have to win soon...
Re: Angle drill
Re: Angle drill
Jim Rutten
>Thanks for your input, Leslie!
Re: Angle drill
Re: Angle drill
Rick Allen
>I find that the moment arm (force that is trying to rip the drill out of your hand) is less on the angle drill when held in it's natural position.
Re: Angle drill
Re: Angle drill
Leslie S
>I also find it is easier to snug up to my body to hold steady than a regular drill. I sanded for a while with a regualr drill and finally sprang for the angle one and really like it much better.
Re: Angle drill
Re: Angle drill
Norm Smith in Nova Scotia
>Jim, You can purchase them pretty cheap on Ebay. Norm
Re: Angle drill
Re: Angle drill
robo hippy
>There are angle drills (chuck comes off at 110 degrees or so), 90 degree drills, and the more traditional in line drill. I like the angle drill because I can get into more places with it, and power sanding is much faster than hand sanding.
Of the angle drills, the Sioux/Milwaukee are the same, and sell for $130 to $160 depending on the model (high speed, slow speed, 3/8 and 1/2 inch chuck). After using both slow and high spees models, I prefer the slow speed ones. When I use the high speed ones, I put a piece of cork under the trigger so it runs slower. Sanding at high speed doesn't seem to get the bowl done any faster than slow speed, I don't loose as many discs off the slow speed drill, and there is less burning of the wood and glazing of the paper. I heard of someone who sells them rebuilt for $60 to $70. There is another knock off model that sells for about $30. I can get about 6 months out of a S/M drill, and about 1 month out of the $30 drill before they need to have the bearings rebuilt.
Sioux does have a pneumatic angle drill that sells for close to $300, and I wore it out in about 4 months. It does keep the compressor running full time so uses a lot more electricity. This would be good in the winter because it will help heat the shop.
I haven't tried the Grex pneumatic random orbit sanders which have the same profile of the angle sanders. One of my friends has one and really likes it. I may have to get one and see how long it takes me to wear it out. I am hard on my tools.
robo hippy
Re: Angle drill
My take
Dave Peebles Lyons, Ohio!
>Hi Jim,
I have Sioux version of the angle drill. I never had had to replace the bearings on mine... I think that is because it has been hanging on the wall since shortly after I bought it. :)
I know a lot of people have them, and love them, but for me and the stuff I turn I could not find a real advantage to them. I have an old Dewalt that refuses to die. I use it on everything I do. Maybe if my shapes were different, I would find a use for the Sioux. But have not, so far.
Best wishes,
Dave
Re: Angle drill
Re:Hey Dave- what would you take....
Jamie Donaldson
>....for that useless drill??? E-mail me if you are interested in selling!
Re: Angle drill
Re: I use all 3 ...
Russ Fairfield
>Which drill is better depends on what shapes yoyu are trying to sand. For what its worth, I use a straight drill, a Milwaukee angle drill, and a small right angle air drill. They all have their advantages, and sometimes it takes all 3 to sand a piece of wood.
The air drill has the advantage that it is smaller than any electric version of a right angle drill - 3" from tip of the Jacobs chuck to the back of the drill motor housing. It spins at 1200 RPM, and I set it to run under load at about half that by adjusting the air pressure.
I use the Milwaukee angle drill for sanding on the outside, and whenever I can on the inside, because it is easier for me to get a firm grip on the drill to control the sanding disc, and move then sand with body motion. I can also hold the drill in one hand while I am using the other to hold the wood for sanding out the rough spots; something I can't do with a straight drill. I usually sand the bottoms this way while the piece is on the bench. I prefer the keyed chuck because it has a protective ring around it, while the keyless does not. That allows me to get a good grip on the head without rubbing the skin off my fingers. Hand-tight is tight enough for all but 60-grit, so there is no time lost with the key. I use separate sanding mandrels for each grit because both the sandpaper and the mandrels last longer that way.
I turn a lot of deep bowls and vase shapes, and the straight drill is the best for getting to the bottom where nothing else will reach. The straight drill is also easier for me to control the sanding disk when it is on the end of an extension shaft.
I use the right angle air drill on the sides of deep vessels because nothing else will work.
Re: Angle drill
Re: Angle drill
Leppikallio
>Ok. Today I heard that little "click" inside my head and a moment later I found myself outside of the store holding Makita in my hand. Unfortunately not turning (or sanding time) next couple of days but at least the drill does work ;-)
Re: Angle drill
Re: I use all 3 ...
Jim Rutten
>Thanks everybody for your help.
Re: Angle drill
Hi Jamie
>But you know no self respecting woodturner will ever sell his spare tools. :) I might be proven wrong and find it is a perfect tool for some future turning. Not that this has ever happened to me before.. :)
Best wishes,
Dave
