We value your privacy.
>For those trying to shoot thier own work I have found a new bulb that works great. These use standard lamp bases so you can use them in regular reflector lamps or the smith Victor reflectors if you have those. I would use the 250 watt in photo reflectors but would stick with 125 watt in household fixtures. You don't want to burn down the shop while taking photos of your work.
These are 250 watt quartz lamps that fit a standard light bulb socket. They are tungsten balanced so you would need to use the tungsten setting on your digital camera or an 80 filter on your film camera with daylight film.
>...soften shadows well with direct lighting. Bouncing light off reflector panels is the easy inexpensive method, and buying big softlight enclosures is the easy expensive alternative.
>Ed To get soft shadows you need big light sources. That's why many people use light tents or large bounce cards. A 10 reflector even with a diffuser is still a small light source if it's more than 3 feet away. The diffuser does tend to make that light a little softer but now much. Usually a combination of a difuser over the light and then another large diffuser between the light and the piece works well. The reason this works is the the first small diffuser even the light out across the larger diffuser. The large panel near the object is what makes soft shadows.
Big light sources give soft shadows and soft highlights and don't show up texture as well. Small light sources show off texture but create hard shadows and bright highlights.
Jamie teaches bouncing the light off a large panel. I teach shining the light through a large translucent panel. Both have thier advantages and disadvantages but both have one thing in common. Large light source. When you have a soft shadow it's easier to fill in that shadow with a bounce card or other means.
The light boxes, light the cube you are talking about is an attempt to produce a large light source by surrounding the vessel with white translucent material. You can build this yourself. If you'll e-mail me at home I will send you plans.
