Re: Scorpion question
GaryG in MD
>Hi Gil,
Since your photo is the exact one in the printed instructions that came with my Scorpion, I'll assume that you are giving me "official" answers.
1) I assume you are telling me NOT to use the washer with the small teardrop scraper -- or, at least, that it was not intended to be so used. I gathered that this would probably be the case, but I'm still interested to know if the washer could be used as a "cut limiter" such as some of the other hollowing tools have to keep them from being too aggressive and catching.
2) Another question: I'm interested in the best placement of the so-called "rotating cutter" (as seen in your photo). In the pic you sent, it is mounted on the 'far' end of the shaft. In this configuration, it does not extend much sideways (in the direction toward the wood) beyond the bulk of the round end of the mounting. I can see this being a problem -- with the mounting hitting the wood. It seems to me that it would make more sense if the cutter bit were mounted (as it easily can be) on the 'near' side of the end of the tool toward the handle. In this way, the round part of the end of the mount does not get in the way of the cutter and will not hit the wood. I don't understand why the 'official' photo shows it on what I would consider to be the wrong end. I would appreciate being enlightened by you, and, of course, by other users.
...Gary
