Refresh my memory: WT article search
Dominic Greco in Richboro PA
>Maybe someone here could help me out here....
I'm looking for an article that was featured in one of the wood turning magazines I read over the past year (maybe a bit more). It detailed a shop built tool handle system that used brass compression nuts, and a turned handle. The area up by the ferrule was cut with a dovetail saw so that the area where the brass compression nut would thread on would act like collet jaws and hold the circular tool steel rod you were using for your turning tool. Using this system (theoretically), you could have one turned wooden handle with a bunch of different style rods each featuring a different tool profile.
I've looked through my collection of Woodturning Design, and American Woodturner Journal. I've also searched through the on-line indexes for these magazines. No luck. Each time I think I have it, I find a different (although usually interesting) article.
You see, I got some shop time about 2 weeks ago. I was able to turn one wooden handle, and get another one roughed and ready to turn. I have the brass compression nuts and have managed to make one tool handle that works just like the article detailed. All I need to do is sneak off for about 1 hour more and I'll be done. But tying to actually plan on some shop time with a 22 month old baby in the house is almost next to impossible! In the meantime, I wanted to read up on the article and make sure I got it "right".
Thanks in advance.
See ya around,
My ugly mug
Dominic
Vicariously enjoying woodturning through all the posted pics here at Wood Central
Re: Refresh my memory: WT article search
Keith Tompkins
Keith Tompkins
>Hi Dominic, I don't recall the article, but one thing I did was to purchase a proxxon keyless chuck. It threads onto any 6mmx.75 shaft. I bought a die this size, threaded a mild steel rod, and made a couple of handles. Now I can fit all sorts of drill bits, allen keys ground into captive ring tools, mini-gouges , whatever into one handle. Works really well!
Mark Wollschlager
>The Spring 2005 American Woodturner had a cove tool set.
Interchangeable set of cove tools that used a brass compression nut on a turned handle.
Could that be the one?
Mark.
Sir William
Jorge Castaneda
>Hi Dom,
Our very own Sir William is very adept at making tool handles with brass nuts, have a chat with him...
$0.03 (adjusted for inflation) : )
Jorge
here's one: it's not the one you remember, but... *LINK*
GaryG in MD
>...Chuck Engstrom had a post here on 30 August of a similar situation.
I remember the article you're talking about, but I can't remember where either. However, check out the following too:
Big Mike (In SW Indiana) had a post here on 13 March 2005, at 2:39 p.m.
John Lucas edited an article on the topic by Brenda Stien. I don't have a date.
After you read all these, you should probably feel comfortable with what you've done.
...Gary
compression nut tool handle
>Dominic I looked through the tips section of American Woodturner and it wasn't in there. Brenda Stein and I both use brass compression nuts but neither of us has tried the split shaft idea you are talking about. I would think you simply thread the nut on in the usual way and then saw the slots later after removing the compression nut. The only problem I see is making the compression nut fit. If you make the tenon too large it's hard to get the nut to seat. If you make it too small the threads won't be strong enough to hold with repeated tightenings from removing the nut. I would make the tenon a really snug fit, using a wrench to install it. Then I would pull it off and soak the end in thin CA. Make sure it's good and dry and then install the nut again.
Another option that a friend uses is the 1/2" quick release collet sold for router bits. It's a little expensive but sure does work good.
Bob Fawcett
>I saw some tools at the Georgia Gathering that I think Jorge made. He had a wood handle and used a piece of steel pipe for a ferule. This had enough thickness and strength to allow drilling and tapping a hole for a set screw to hold the tool in place. He used the same handle for several tools.
Thats IT!
>Mark,
That's the one! American Woodturner, Spring 2005, Vol 20 No.1, Pg 52. "The Cove Tool", By Stacey Hager
Just today I was looking through a stack of FWW and stumbled across that issue way at the bottom. No wonder I couldn't find it! But there in the back was the article on making a cove tool and it showed the bit about making the ferrule from a compression nut (as William Duffield showed me at the recent 5 Barn's BBQ)
Thanks again!
Dominic
Thanks John
>John,
You wrote:
"Then I would pull it off and soak the end in thin CA. Make sure it's good and dry and then install the nut again."
That's exactly what the article advised. I remembered reading that, but wasn't completely sure about it. Now I know for certain.
To be honest, I'm figure I'm not going to be changing the tool bit all that often. I toyed around with the idea of sharpening one end of the tool rod with one profile, and sharpening another type on the other end. But to be honest, I'd end up using one end just cause I'd be too preoccupied (i.e. LAZY) to bother with the whole loosen-swap-tighten ordeal.
Thanks for the info!
Dominic
Re: See what I meant before, John?
Allen Neighbors
>Your posts are always so informative. And well written... easy to understand. Thanks, I appreciate you.
Allen
Hi Jorge!
>Jorge,
William was the one who first got me on this make-your-own-turning-tool thing in the first place! I saw his 3 point tool at the most recent 5 Barn's BBQ and thought it was pretty cool.
I've got the compression nut in place. I just wanted to read up on using it like a collet to hold different tool rods with different grind profiles on them.
As Mark Wollschlager was kind enough to look, I'll give him full credit for finding the article I was talking about. It's in the 2005 Spring issue of American Woodturner, Pg 52, "The Cove Tool" by Stacey Hager.
See ya around,
Dominic
See ya around,
Dominic
Thanks everyone!
