We value your privacy.
>I have started my first Norfolk Island Pine hollow vessel. When I hollow the inside, will the knots come flying out when I cut through them and should I apply CA glue before hand. Also, what is the best finish for a translucent piece.
>It might be a good idea to put CA around each knot, in fact, cover the whole knot, let it soak in. I put the CA on when I get the bowl down to 1/2" thick because they may pop out, just get loose or crack.
I've found the best solution is mineral spirits, boiled linseed oil and a quart of spar varnish.
>For what it's worth, I've never heard of NIP knots coming out. The few I've turned didn't even think about it. As mentioned above, Russ' home brew of equal parts mineral spirits, BLO or Tung oil, and spar varnish (other wise known as danish oil) is the finish of choice. Cycles of 12 hours soaking in DO and 12 hours to drip dry repeated between 12 and 20 times until level of translucency and smoothness of finish is achieved. Sounds like a lot of trouble, but is well worth the effort.
>The actual proportions for the finish are 2 gallons of odorless mineral spirits, 1 gallon of BLO and a quart of spar varnish that uses alkyd or phenolic resins. Russ said the odorless spirits seemed to work better - good enough for me.
>As an update, I finished the hollow vessel to less than 1/8" (without going thru the sidewall) and have submerged in Russ' finish. I plan to remove tomorrow, let dry 12 hrs and repeat. Somewhere I read you do that 20-25 times. Don't know if I can wait that long, but will try.
