This is a test!
This is a test!
This is a test!
Allen Neighbors
>What's wrong with this picture?
Re: This is a test!
Re: I was so ready to test out
Allen Neighbors
>the steady rest, that I forgot to move the tool rest toward the tailstock. Installed the steady rest, moved the tailstock out of the way, and couldn't find the tool rest. :o(
Had to do it all over again. :o)
not-so-methodical-Allen
Re: This is a test!
tm
>Glad to answered the question...
my brain was going into spasm trying to figure it out.
tm
Re: This is a test!
Jim
>I was gonna say....
"How in the world are you going to get a tool up to that thing? And what's the point of the tailstock still there if you have the steady?"
Of course if you're busy installing the steady, (I mean look at all the nuts you have to adjust and tighten up) you tend to forget details like where the tailstock and tool rest go....
You're not alone....
Re: This is a test!
Allen Neighbors
>Jim, the tool rest in place shows how quick my mind is. I discovered my hasty mistake, then moved the tailstock back into position to make the switch, and then decided to take the pic. And forgot to remove the tailstock.
Cool, huh.
Re: This is a test!
Leo Van Der Loo
WHERE'S THE PILE OF SHAVINGS AND SAP STREAKS,
Leo Van Der Loo
>THAT PLACE IS TOO CLEAN, AND THAT WAS ALL I THOUGHT WAS WRONG (Grin LOL)
Have fun Allen and take care
Leo Van Der Loo
Re: This is a test!
Re: This is a test!
Russ Fairfield
>What's wrong with the picture is that the lathe has never been used. Is it in your livingroom??
Re: This is a test!
Re: This is a test!
don in central IL
>What's wrong? It is in the wrong shop, it's supposed to me in mine!
Re: This is a test!
Re: This is a test!
Russ Fairfield
>It doesn't matter where you put the steady rest or banjo when you never use them. {8>)
Re: This is a test!
Re: This is a test!
Chuck Engstrom
>Hi Allen -- I kept having the same problem with a project a couple weeks ago -- I'd want the tool rest first on one side of the steady rest, then on the other side, etc. Removing tailstock etc to make the change got to be a real pain, so I replaced the nylon-insert locknut of the banjo clamp with a standard free-turning nut same size. Now when I want to change, I just take that nut off by hand, move banjo, and put nut back on. In ordinary use, if I find the banjo lever seems not to tighten to its usual angle, I just reach under and turn that nut on a little tighter. MUCH time saved in the long run.
Best--
Chuck Engstrom
Re: This is a test!
LOL LOL LOL!!!!!!
RevDoug
>Who says Russ has no sense of humor. This is one of the funniest lines I've read on here in a long time.
Turn 'em round,
Re: This is a test!
Re: That would work alright,
Allen Neighbors
>but I don't want to have to keep adjusting under the bed... that's what used to bug me about Old Griz. This OW Banjo is awesome the way it is, I just need to remember to move it outside the piece before I install the steady rest. :o)
Re: This is a test!
Re: Glad I posted this...
Allen Neighbors
>I thought it might bring a little levity to the forum. But I didn't know I was such a clean freak! Too clean??... others are always telling me I'm such a slob. :o)
(Hope you didn't hurt something, tm.)
In my living room?... LOL, Russ. Marolyn loved that one.
About once a month, I open the doors, and turn on all the exhaust fans, and go through the shop with my airgun, blowing the dust off everything from floor to rafters. The dust looks like smoke coming out all the openings!
Re: This is a test!
Carol from AZ
>"The dust looks like smoke coming out all the openings!"
I did that often in my shop in California. The first time, the neighbors called the fire department! They in turn, then thought it would be a wonderful time to 'inspect' my shop! Oops!
Fortunately I had fire extingishers at each door and no solvents stored in the shop. So I passed. Whew!
Re: This is a test!
Allen Neighbors
>Don't have any inspections of that sort, here. But I do have one fire extinguisher on hand.
I am a firefighter, and we welcome all calls... it's better to get an unnecessary call, than to have a real fire somewhere and have the call delayed. Actually, it was kind of embarrassing the one time we did have a fire here. :o)
Allen
Re: This is a test!
Brad Vietje
Brad Vietje
>Allen,
I clean my "shop" with a rake and grain shovel ! About once a month I use an actual broom. Let's see some curly-q's all over that floor !
Great looking lathe & steady rest -- hope you get to use them soon and often.
Safe spinning,
Brad Vietje
Newbury, VT
Re: This is a test!
Paul Porter
Huh...your lathe is too clean. :>)
Paul Porter
Re: This is a test!
Yes, That's it!
Jorge Castaneda
>Totally antiseptic, that is what is wrong with it, you need a mess in there! : )
Jorge
Re: This is a test!
Re: Yes, That's it!
Ed Karch
>I have sliding glass doors at one end of the shop. I use a leaf blower to dedust. I shovel out the shavings when my lathe seems too low.
Re: This is a test!
Chuck Engstrom
>Yes, understood. But bear in mind that the Oneway bed design makes the underside of the bed far more accessible than most others -- there's nothing in your way on the operator's side, so you don't have to be a contortionist to reach under there. It would be a different matter on most others.
Best--
Chuck
Re: This is a test!
Allen Neighbors
>True, true. But I do a lot of turning on both sides of the bed... right handed and left handed, especially on hollowforms/vases.
But I really do love the accessibility of the underside of the Oneway.
