We value your privacy.
>HI Lester, try this. First, set your guides. It's important that the blade is centered on the wheels to start. Then, adjust the rear rollers, top and bottom. They should barely touch the back of the blade while rotating the wheels by hand, no load on the blade.Next, set the side guides. TAke a look at the guides...if worn, they can be reversed or re-ground flat. Make sure the guides are not pushing the blade unevenly to one side,and they are situated back far enough that they don't contact the blade's teeth. For conventional guides or coolblocks, a piece of thin paper inserted between the guides and the blade acts as a clearance guage. Loosten both guide set-screws, apply equal finger pressure to both, and tighten the guides. This simplifies the operation. Set both upper and lower guides in the same manner.
Next, mark a straight line on a piece of scrap wood, and saw along the line. If you have to hold the wood at an angle to the saw table while cutting, the blade is pulling to the side instead of cutting straight. If the blade is new, you can compensate for this (or take it back for exchange) , if old, replace it. At this point you can be pretty sure the blade is the problem, NOT the guide adjustment.
I don't know the radius of the spiral you are cutting, so make sure a 1/2" blade can make the curve freely without binding in the cut. You may have to switch to a thinner blade, requiring a new set-up of the guides.
Last, use the back edge of the blade as a guide....you can actually pivot the wood against the back edge, which gives much better control than just cutting freehand. Hope this helps, Keith
