We value your privacy.
>I have often heard of people taping small holes/bark inclusions/etc. in order to get a better hold when vacuum chucking. I have a few questions - what kind of tape do you use, and do you tape inside the vacuum chuck or on the outside of the piece. Thanks in advance for any advice.
>I have neer done this, so it may be a bad idea or wrong.
I would use duct tape on the opposite side from the chuck. The wood would support the tape, and vacuum would have to pull it through the hole. duct tape should be strong enough for a small hole.
>Dawn, Bob, I'd be careful with duct tape. I've used it to wrap the ends of 2Xs while hauling, when removing it takes wood with it! Try the wide blue painters tape. Mike
>I like electircal tape. It sticks to itself well, but not to wood. It's cheap. It's less pourous than masking tape. If the holes are boig, or if it's pourous wood (bubinga end grain comes to mind) I use saran wrap.
>Woodturners seem to like living on the wild side of the safety issues. Personally, I always listen to Murphy's Law - if it can go wrong, it will. If I can't hold a vacuum with the wood alone, I will use another method to hold the wood. To me, it isn't worth the risk to be patching the holes with tape or shrink wrap.
I already know that this is a personal opinion that is not shared by very many other woodturners.
>I share your opinion although I have used some of the above methods. A good thing to remember when ever you use a vacuum chuck is some things can and will go wrong sooner or later. Stay out of the line of fire, use slow speeds when you can and use the tailstock as long as possible. No piece of wood is worth spending time in the hospital.
Even when you think everything is perfect,*%^#*& happens. I remember using the vacuum chuck once and for whatever reason I lost power to the house. The lights went out, the vacuum pump stopped and I had a bowl bouncing around the shop in the dark. That was nerve wracking. Fortunately I had followed my advice, which is stay out of the line of fire.
>Thanks so much for all the advice. I had a small crack in burl wood and when I put it on the vaccum chuck, it whistled. Interesting tune as it spun around! The piece would stay on like this, but I wanted to make sure it was secure. Blue painters tape worked wonders and did not mark the wood at all. Hurray!
>You don't need the power to go off. The first time I used mine I finished turning and sanding the bottom and wanted to take a look to see how well I had done. So I did just what any other idiot would do. I reached over and turned off the pump instead of the lathe. I think I was the only thing in the shop the bowl didn't hit.
