ADVERTISE HERE - FREE TRIAL
Still can't get chat to work
Tony Reynolds somewhere near Newark, Ohio
>Hi all,
I still can't get the chat to work on my new laptop. HP P4 XP media edition. The Sun Java coffee cup comes up and attempts to load but fails to load and I get the red X. I've tried it in IE6 and the latest Firefox browsers with the same results. Java works on other sites so I think my settings are ok. Any input much appreciated.
Tony
Re: Still can't get chat to work
Re: Still can't get chat to work *LINK*
Ron in Drums PA
>try downloading and installing the lastest version of Java
Java
>Thanks Ron, but I've already done that.
Tony
Carole Valentine
>Have you enabled Java in your browser settings? And have you tried with any firewall and anti-virus turned off?
This is the Error message I get....
>in the JAVA console in IE6:
Java Plug-in 1.5.0_08
Using JRE version 1.5.0_08 Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\Tony
load: class ParaChat.class not found.
java.lang.ClassNotFoundException: ParaChat.class
at sun.applet.AppletClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadCode(Unknown Source)
at sun.applet.AppletPanel.createApplet(Unknown Source)
at sun.plugin.AppletViewer.createApplet(Unknown Source)
at sun.applet.AppletPanel.runLoader(Unknown Source)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.io.IOException: open HTTP connection failed.
at sun.applet.AppletClassLoader.getBytes(Unknown Source)
at sun.applet.AppletClassLoader.access$100(Unknown Source)
at sun.applet.AppletClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
... 10 more
I have tried with anti-virus and firewall turned off, in both browsers. JAVA is enabled in both browsers.
Tony
Not sure, but... *LINK*
>...check out this link and see if it helps. Let me know if it doesn't.
Ellis Walentine, Host
Parachat Java Help
Tony Reynolds
Re: Not sure, but...
Tony Reynolds
>Hi Ellis,
That's the problem I'm having but the java control was already set to use browser settings. I'm not using a proxy server so I don't think that applies, but could be wrong. I did try it with a 8080 port address but no joy.
Tony
How about non-Java chat? *LINK*
Ken Grunke from SW WI
>Ellis, can you install php programs on the server? I have a simple PHP chat installed on our chapter website, it's trouble-free and easy to use.
If not, there are Perl cgi equivalents to the Java chatrooms which always seem to get some people (like me) tummy aches!
Anyone is welcome to check out the link below, and try it out.
CRW Turning Chat
