vacuum system
vacuum system
vacuum system
bmac
>Well, I got my vacuum system up and running. I attended the GA. Turning Southern Style Symposium and purchased a Hold Fast vacuum chuck and the adaptor kit for my lathe. Installed it on my powermatic and hooked up the vacuum pump I got on e-bay. Works like a charm. I wasn't sure what to expect on holding power, but it was great. I put on a walnut platter that I had turned the front side of several months ago but didn't have a way to finish the back. It took awhile to get it centered but I was able to finish the back with no problem. The platter is 11 1/4 in. in dia. and finished with walnut oil.
Bobby
Re: vacuum system
Re: vacuum system
bmac
Re: vacuum system
Re: vacuum system
bmac
Re: vacuum system
Re: vacuum system
bmac
Re: vacuum system
Re: vacuum system
Bill Neddow
>A nice, simple, clean and professional looking set-up. No wonder it works so well.
Re: vacuum system
Re: vacuum system
Sean Troy
>Best Wood tools has a tail stock adapter that is perfect for centering turnings for vacumm chucking.Thread the adapter on your chuck thats holding your turning, insert it in the tail stock by the taper and push your tailstock towards the drum. After you get the vacumm going , undo your chuck, replace the adapter with a live center to hold your piece in place until you just need to finish the small center nub.
Re: vacuum system
Re: vacuum system
Hooligan
>I've been serioulsy considering this system, and the venturi type control. I have a little one gallon compressor that will do 3CFM at 60 PSI that I've hung on to just for it. Its quiet, and runs like a champ. You might just have pushed me over the edge.
Re: vacuum system
Re: vacuum system
Bill Hale / Woodspinner
>If you start between centers you will have a center mark on the backside.
Vacuum off, put the work against the vacuum fixture and center the work by the tailstock. I kind of rotate the work piece back and forth a little before tightening and applying vacuum.
Fast and simple
Bill in Cassa Grande, AZ.
Re: vacuum system
Re: vacuum system
bmac
>Thanks for the comments and the suggestions. They are always greatly appreciated.
Bobby
