Rolly Munro Mini Hollower -- SWEEEET!
Ed Moore
>After several strange twists, I ordered the Mini Hollower from Binh Pho and received it promptly. My initial reaction was surprise at how small the cutters are. I just measured them and they are 9/32". Well they were plenty aggressive and I set the cover so the shaving would be thinner.
My first use of the Munro hollower was hollowing the interior of a small cherry goblet and it went well. Since there is a learning curve for the Munro, I chose to clean up the cuts with a curved scraper, but it was clear that with some practice that might not be necessary. This was also my first goblet and I didn't want to blow it. Thank you Jimmy Clewes DVD's. It would not have occurred to me to use a 1/4" bowl gouge (standard grind) for the exterior and the stem had I not seen it on Jimmy's DVD.
My conclusion is that the excellent reputation of the Munro hollowers is well-deserved. I am looking forward to trying it on small boxes.
Observation: In Jimmy's DVD where he turns an end-grain vase, he introduces a variety of hollowers. Now his name is on a Hamlet combo set. But in the DVD it is clear that he does most of the hollowing with a Munro. Hmmmm!
Ed
Re: Rolly Munro Mini Hollower -- SWEEEET!
David Galloway
>Well, you did it to me. I was on the fence but I had talked to Binh about the tools. I just needed a nudge and you were it. I would love to hear more from you as you learn the tool. I should get mine by the first of next week!
David
Hooligan
>I've been fighting the urge to go that route. I am up in the air between the Munro, and the Stinger from Pencil.
Cherry goblet
Ed Moore
>This cherry goblet was the one I referred to when using the Munro Mini.
7 7/8" high
2 1/4" dia cup
2 1/8" dia base
stem tapers from 5/32" to 13/64"
The cup is 1/16" thick.
Comments/criticism welcome.
Ed
Hooligan
>Actually, have you got a source for pictures of the Mini? And what it contains? That is of interest to me, I was assuming that it would be just like the standard, but smaller....
Re: Cherry goblet
Allen Neighbors
>The old gray guy likes it! Nice work.
Allen
Carroll's Woodcraft (AU) *LINK*
Ed Moore
>Hooligan,
Check out the URL below for Carroll's. The picture is there. The prices are Aussie, so don't panic.
It comes with a cutter and two extra. It includes the sharpening jig for the 8 mm cutters and a tool with three Allen wrenches. It also has a little piece of clear plastic which is used to set the cover for the tool - be careful or you will miss it.
Order from BINH PHO.
Ed
Carroll's Woodcraft
Re: Cherry goblet
Mark Wollschlager
>Nice looking work Ed.
Did you use a string steady or just take it slow and easy?
Mark.
Re: Carroll's Woodcraft (AU)
Gil Jones
>235 Australian Dollar = 176.584 US Dollar (at todays rate)
Re: Cherry goblet
Ed Moore
>Hi Mark,
Have you been keeping the Stubby busy? I have the supports under the shop and am preparing for an ornament demo on the 28th.
I stuffed some paper towel in the cup and brought the tailcenter up to reduce the wobble. By using the 1/4" bowl gouge on short sections it worked pretty well.
Ed
Hooligan
>So, its just the straight tool? :( I understand that its an articulated head, but I that leaves you short on a high shoulder. Hrumph.
Mini hollower picture
Ed Moore
>Hooligan,
Here is a picture that I just took of mine. The focus isn't perfect, but it should answer your question/concern.
The picture shows the Allen wrench tool, a spare cutter and the sharpener, and the tool. There is some articulation, but it lacks the arms we see on it's larger cousin. I do not know if any small arms are available, but I don't recall seeing any mentioned.
Ed
Re: Cherry goblet
Mark Wollschlager
>Stubby has been nice and busy.
The Jet mini is jealous.
Ornament turning on the Robust, that ought to be fun ;-).
mark.
Nice Ed
Ron in Drums PA
Re: Cherry goblet
Jim Shaver Oakville, Ont.
>Hi Ed,
That looks beautiful, I bet it's light enough to float away...
Wonderful!
Take care,
Jim
