We value your privacy.
>...the new edition show's a spindle lock that uses a tapered piece of wood tied to the motor handle with a piece of string. I think I have come up with a better idea on my Powermatic.
Drill a small hole in the finder thingy that protects the lock button
and insert a small allen wrench or whatever you might have around.....works great.
>...(that wasn't really stressed in the AAW magazine article) is that the "wedge" can position the spindle ANYWHERE, rather that in an indent that the lock button uses.
This would allow carving, sanding or whatever in any part of the circumferance in a position other than the fixed spindle lock positions.
>Joaz, that really is a good idea you came up with and I only wish I could figure out something similar for my General 260. The spindle lock is inside behind the headstock and I have to use a lever (screwdriver) to loosen it to set the lock in the holes each time. It discourages me from doing anything where I would need it.
>Ruth, don't we have the same General? Mine is a spring loaded spindle lock that you have to hold in to keep it locked, but the indexing pin is a spring loaded device that I use sometimes if I need a hands free spindle lock. What are you using a screwdriver on?
>I threw the string away. I kept breaking it anyway. I just tuck the wedge between the motor and the headstock case when not in use. it's a perfect storage area and it's not in the way and easily accessible when needed. I got that tip in the mail and it was just a drawing so I built it and took the photo that was in the journal. I've used it a lot ever since. It works great.
>I think that tip along with another was already in the journal. Another one was to simply remove one of the allen screws and loosen the other one slightly. Then you simply pushed in the button and rotated the cover to cover the button. This one doesn't even have part you could lose.
But, doesn't the button on yours only lock in two opposite positions ? Mine (3520-B) does this, so a method to lock it wherever I wanted would be great, and easier indexing would be a real plus, too. I used the indexing "feature" which is functional, but pretty cumbersome, with the little threaded pin and the tapped holes. There must be a better way...
>Jen, I use a lever to get the spring-loaded spindle lock loosened to be able to set it in the holes. Once it's out, I have to be sure to only pull it out of the hole just enough to turn the spindle to the next desired hole. If it springs all the way back, I need the screwdriver (or other type tool) to loosen it again.
