simple, cheap lathe
victor
>hello
can anyone tell me where i can buy a lathe that is powered by a handdrill, i can't find any info on the internet maybe it has a special name?. i need one only for making chisel handles.
simple, cheap lathe
victor
>hello
Re: simple, cheap lathe
Joe Herrmann
>There was one out that mounted to your drill press on the market sometime back. I think it was called a "Vert-i-lathe"
Joe
thad
>I've seen several up on eBay from time to time.
Re: simple, cheap lathe *LINK*
Ralph
>Grizzly sells one http://www.grizzly.com/products/h2669
But I think you would be better off spending an extra $100 and getting a mini-lathe
The lathe
Bobby Wisdom
>I'm sure a hobby woodturner would make a few chisel handles for a minimum price. They are quick and relatively easy. You might ask at your local woodworking store for a reference. It should save you a few bucks if you really aren't interested in turning.
>My first lathe was an electric drill. I simply mounted it handle up on a board. I put a screw in the chuck to drive the wood. Then I made a tailstock by making a L shaped bracket that I clamped to the workbench and put a lag screw threw it that I had sharpened to a roughly 60 degree point. For a tool rest another L shaped piece of wood with the top edge planed to an angle, was clamped to the bench. I did this specifially to turn cabinet knobs and tool handles.
