epoxy filler
epoxy filler
epoxy filler
Georg Waldhof
>I'm turning a burl with a lot of voids which, for the specific purpose at hand, need to be filled.
What epoxy filler does anyone recommend? Bear in mind, these are not small checks but rather largish voids and checks.
When I say large, some are big enough to insert a finger to the second joint. Filling them with pigmented epoxy is my plan and will be precisely what I want as far as appearance goes, I just am not sure which epoxy is best for this sort of thing.
also, what sort of pigment does one use and how much? Or is that one of those "test and see" questions?
Many thanks
George
Re: epoxy filler
Re: epoxy filler
Rick Allen
>Epoxy filler.
I find it more successful to rough turn the piece first. This will give better access to the voids and limit the amount of epoxy needed.
It is important to "wet" the void(s) before filling with colored epoxy. "Wet" means to apply a coat of epoxy first which will form a barrier and bond for the thickened and colored epoxy.
Warm the wood before "wetting" the void(s). Warm wood will thin the epoxy and provide deeper penetration that results in a stronger bond.
I usually back the void with duct tape.
Epoxy? West, Evercoat, Mas, or any marine epoxy is a good choice. I prefer West with the "slow" hardener. The "slow" hardener is the clearest in the hardener line of West products. That clear epoxy helps with other epoxy uses.
There are several filler available. The filler I like best is 407. The filler will make the epoxy thick enough and opaque enough that it is easy to work with.
There are many many colorants and a little colorant goes a LONG way. I like the polyester colorants but there are many which work well for this application.
Get the pumps for the epoxy. The pumps make getting the right amount a no-brainer.
There will be bubbles in the epoxy. "Encourage" the bubbles out. This can be done with vibration (running a ROS on the pieces gives that sort of vibration). Some recommend breathing on the epoxy. I also prick the bubbles as I detect them.
Apply heat during the last hour of cure. It is hard to tell when this last hour is. But some heat (120 degree is perfect like from some work lights) will finish off the cure nicely.
Sand the cured epoxy. You should get a non-cloging powder from the sanding. If the sandpaper clogs then wait another day.
The epoxy should cut and sand well as you fish the turning once the epoxy has cured.
Re: epoxy filler
Re: epoxy filler
Chuck Engstrom
>There are lots of epoxies out there; almost any would be suitable, though I would stay away from the quick-cure 5- and 20-minute stuff, which probably wouldn't penetrate nooks and crannies before setting up.
I've used System Three products for over twenty years and like them very much. They mix two parts resin to one part hardener (several "speeds" available) and if you buy their hypodermic-like measuring gear, you can mix as little as two cc's resin with one cc hardener with confidence--I have done it often measuring carefully. This saves BIG $$$ over the WEST pumps, which often need a priming stroke that you throw away since it's probably not measured quite right, and one proper stroke is more than one usually needs for this sort of job.
Some folks use dried used coffee grounds as filler in areas that are bark-like. THe epoxy has a light amber color but you'd hardly notice it used this way.
White vinegar is cheap and safe clean-up for hands, tools, etc. before epoxy sets.
Best--
Chuck Engstrom
Re: epoxy filler
Re: epoxy filler
Georg Waldhof
>Many thanks!
This was precisely the information I was looking for.
George
Re: epoxy filler
Re: epoxy filler
Merv in BC
>I agree with the slower cure epoxy for void filling It not only gets into all of the nooks and crannies but allows most bubbles to escape. Mix it slowly without folding to avoid bubbles. I use several of the coloured crafts fillers from Micheals Craft stores and like the blue and black glitter the best. Coffe grounds are also quite good if you just want brown. If you want it darker go to stabucks and get their used dark roast.
If pockmarks occur due to bubbles use the 5 minute with the same filler to fill them. On a large hole back it with duct or masking tape to hold the filler in place. filling should be done as the last step in turning and the excess can be scraped off with a small 1 in paint scraper
Re: epoxy filler
Re: epoxy filler
Pete LaBelle
>Many of us have vacuum systems for chucking.
The Advanced Composites studio where I work have a vacuum chamber that all epoxies, urethanes and silicone mixes go for a short time to draw the air out of the mixture after mixes but before pouring. Might want to experiment with that to de-aerate your mixes. Careful though: Mixes with a lot of air will froth up during the de-airing process before they settle down.
Pete
Re: epoxy filler
Brad Vietje
Re: epoxy filler -- A little further, Please
Brad Vietje
>I'm quite interested in this topic -- but I want to fill a big crack with something SILVER -- with a metalic sheen, if possible. Would one of the metallic polymer clays work ? Is there a metallic filler for epoxy ? Should I grind up some solder and stir that in ?
Advice ?
Safe spinning,
Brad Vietje
Newbury, VT
Re: epoxy filler
Rick Allen
>I have used metal powders as filler for the epoxy. It takes a LOT of metal powder to get the effect of metal. Aluminum powder would work for that silver look. Expect to use 50% metal by volume. The epoxy will not be as strong with this much filler but a void doesn't need much strength. The finner the powder the more filler you need and the closer to the effect you become. A fine aluminum powder at 25% may look more gray than silver. Even 50% can look gray. Brass takes on a green cast when the % is to low for the fineness of the powder.
The best effect I have seen is with metal leaf. Fille the void, turn, sand and and apply silver (or imatation silver) leaf over the patch. The put a film finish on the whole piece to protect the metal leaf.
There are a lot of other topical coatings you can use to get the silver look.
When I tried PC I was less than thriled with the result. I found it dificult to get the bond I was expecting to the wood and the cureing process made everything worse. I gave up on PC before I resolved a lot of the isses. There are PC clubs and forums where you can get some good information about PC.
Good Luck
Re: epoxy filler
>Brad check into Pewter to fill the void. It's solid metal. I have never been totally pleased with the results of mixing metal with epoxy. Larger chunks of metal placed close together look pretty good. I've never been able to get metal powder to look really shiny like metal.
Re: epoxy filler
Leo Van Der Loo
Leo Van Der Loo
>Hi Brad
My experience says you can't get enough metal or any other mix into epoxy and still have it look like metal and the epoxy still work.
I get the best results by filling a void totally with metal powder/shavings and then fill the space between the metal particles with CA, if a large void or crack/split then partially fill with whatever first, and then do the metal and CA.
It still won't look like just scraped metal, but a heck of a lot better than the epoxy/metal mix.
I have a little black ash bowl here with some brass shavings in it and made a quick pic., to give you an idea of the look I get with the CA and metal.
For a silver look I would get some stainless steel slivers, if you can get them, I think you will get the best silverlook with that.
Have fun and take care
Leo Van Der Loo
