Is it Live?
Is it Live?
Is it Live?
Phil Joines Krum, Tx.
>The pic is the live center that comes with the Jet mini lathe disassembled.
It shows the Morse adapter, the inside of the center�s nose, the original bearing and a replacement bearing.
The original bearing has a metal shield on the tailstock side but the headstock side is open. It�s marked NTN Taiwan 60022. The second bearing is the replacement, obtained from a local supplier, it�s an MRC (France) part #102KSZZ it�s sealed on both sides. The cost was $21.32. The metal "shield" won't keep fine dust out.
It�s fairly easy to tell when one of these is going bad. With the adapter held motionless try to spin the nose. If it feels bumpy or as in my case won�t turn at all the bearing needs to be replaced. The cause of the failure is the type of bearing used. It�s open on one side allowing dust to enter. I had already cleaned most of the crud out before the pic was taken. The dust hardens the grease and packs the space between the balls. I figured a replacement from Jet would be the same type with the same problem.
To disassemble I held the nose piece in one hand with the adapter pointed down over a table. A piece of 1/4� steel rod was inserted into the open nose at an angle so it rested on the end of the adapter. Using a 12oz hammer and light taps both the bearing and adapter where knocked out. In my case the parts came apart with out any trouble but it the fit had been tighter the rod could have been moved from side to side to press the bearing out evenly. I used my pen press to reassemble it. If you need to replace yours just take the old one to a bearing shop and ask for a double sealed replacement. There are lots of good ones out there.
This is a simple repair and the replacement should last until the lathe wears out.
Re: Is it Live?
Re: Is it Live?
Allen Neighbors
>Phil, thanks for posting this. Both of my Grizzly live centers are a little rough. Good information!
Allen
Re: Is it Live?
Re: Is it Live?
>If you're on a tight budget, once you've disassembled the live center, and before you spring for the new sealed bearing, you might try cleaning out the old bearing by soaking it in acetone or other solvent, spinning it and brushing out the crud. If you can get it rolling smoothly, you can probably get quite a bit more life out of it.
Repack the bearing with bearing grease. Make sure you reassemble it with the shield facing outward.
To keep it from clogging up so quickly next time, try stuffing the hole through the MT with a bit of oiled paper towel. Also, note that dust gets into the bearing much more quickly if it is operated without the center point. This end can also be sealed up with the oily paper towel.
