Anyone turned Water Buffalo Horn ?
Brad Vietje
Brad Vietje
>I just ordered some water buffalo horn for a wedding ring I've been asked to make -- and the guy who sold it to me wants a pair of rings for his wedding in about 60 days, too ! Anyone ever turn this stuff before, or have some advice about making a ring from horn ?
Thanks,
Brad Vietje
Newbury, VT
Re: Anyone turned Water Buffalo Horn ?
Steven Antonucci
sort of...
steve antonucci
>I've never turned waterbuffalo horn first hand, but I have made a few knives and WBH is a favorite amongst the knife making set.
I understand that it stinks like H*LL when you do anything high speed (burning hair smell), so sharp tools and control your speed and cut. (supposedly, all horns smell bad when machined...)
Check out knife making forums for the skinny on WBH...
Steve
Hooligan
>I have, the stuff is horrid. I hate it, stinks, and it a mess.
I've found that working with forged gouges works better than sadard, no idea why. and try your danrdest to NOT scrape. It does seal and polish well, though.
As far as a ring, I would think that the stabilized variety is much more adept for that sort of project.
eaglesc
>I haven't turned rings but have made pens with it.A word of caution.Some of the penturners who have used it wexperienced craking after the pens were turned. Since you will be using larger final thicknesses it may not be an issue.
Blow is a pen I made with WBH and white tail derr inlay.
Since I use CA to glue up and stabilize I may have beat the craking problem along with the addition of the WTD antler.
Phil Joines Krum, Tx.
>I haven't turned WB horn but cow horn turns a lot like plastic. I found shear scraping with a sharp skew (held up at about a 45 degree angle) worked well to get a smooth final cut. Sanded from 220 to 800 and buffer with white diamond.
To mount the rings I used a piece of dowel in the chuck. Cut a tennon to fit the drilled hole with a press fit. Finish one side, flip it over and do the other. Make a jam chuck to do the inside. Be sure to round over the inside edges a bit.
Keith I in E. Tenn
>I havn't turned any yet but plan on turning a pen/pencil set for a gift. I read somewhere it needs to be soaked in cold water for several hours. Seems like it would crack when drying.
Keith
Tom Libby
>How is the horn "harvested"? Who could tell it from plastic?
Steven Antonucci
I have to say you make some nice freakin' pens!
steve antonucci
