I turned my first pen today
Bart Leetch
>A Rose Wood Comfort Pen. This pen turning may give me many hours of enjoyment.
I finished it with a shop made plexi glass finish.
Re: I turned my first pen today
Allen Neighbors
>Nice pen, Bart, but what's a shop made plexiglass finish?
Allen
Ron in Drums PA
>Nice Pen Bart.
What I like about pen turning is there are times I only have a short time to turn something. I can finish a basic pen around in 15-30 minutes and walk out of the shop with a completed project.
Ron in Drums PA
>I've never made this finish myself, but basicly you disolve plexiglass in a jar of acetone and use the mixture as a finish.
Bart Leetch
>By Terry Miller
Plexiglass Finish
To start you need to make a thick solution. I did this by melting plexiglass in acetone. I
started with a new 1 gallon paint can from any box store or paint store. I used enough
plexiglass to cover the bottom of the can with about 1-2 inches. I then added enough
acetone to cover the plexiglass. For the next couple of days I would stir the solution
periodically and add more acetone as necessary.
After the initial solution is made you need to take some of the solution and thin it for the
finish. I thin the solution to a consistency a little thinner than thick CA glue. This can be
adjusted to individual preference. I tried the thick solution and it did not work for me the
finish just clumped up because the quick drying time. I keep my thinned solution in a
squeeze bottle that was purchased at a beauty supply shop. I have had it in the same
bottle for about six months with no problems.
To start I turn the pen just as I would with any other finish. I turn my pens, sand and
finish with the lathe running at the same speed about 1800 rpm�s. I sand with 150, 220,
400, and 600 and then stop with the first grit of MM. Prior to applying the finish ensure
that you don�t have any sanding rings or defects.
At this point I wipe the blank with DNA with the lathe running.
To start with I use rubber gloves and apply the solution with a paper towel. I won�t get
into specifics as to which paper towels because of debate over which is better. I fold the
paper towel up to where it is about a � of an inch wide.
I start by soaking the paper towel with the solution. The first coat I start applying the
solution at the nib end of the pen and work toward the finial end. After each coat I apply
a small puddle of solution to the paper towel. Unlike the CA finish I use the same
portion of the paper towel. The only time I switch to another section of towel is if I delay
between coat and the solution on the towel dries. Each coat after is started at the opposite
ends of the pen to ensure an even coat on the entire pen.
I apply as much solution as I feel necessary to the blank. I typically apply between 5-10
coats. This varies depending on the amount of solution applied to the paper towel per
coat. This finish can be sensitive to the amount of pressure used to apply it. I have found
that if too much pressure is applied during the process the finish will flake of resulting in
you having to start over again with sanding. After the last coat is applied let the lathe
continue running for about 30-60 seconds for the solution to cure.
At this point start wet sanding. Depending on the smoothness you have after applying the
solution it will determine which grit to start with. I usually start wet sanding with the
first grit of MM and wet sand all the way through. The first grit I will spend about 30
seconds the rest of the grit I sand for about 15 seconds each till the last 2 which I once
again spend about 30 seconds each. Between every couple of grits I will wipe the blank
down with a paper towel moistened with water.
Once the sanding is completed and the finish is smooth I move to the final stage of
finishing. I use a plastic polish that was purchased at Wal-Mart I believe that it is GS-27.
I apply 2 coats to make sure that all scratches are removed then follow up with a coat
Meguires car wax.
Once all of the steps are completed I remove the blank from the bushing with a pair of
pliers with a slight rocking motion. I then carefully trim the excess film left on the end
with a straight edge razor blade. Then finish assembly of the pen as per the instructions
I have found that some oily woods benefit from a sealer coat of CA prior to applying the
Plexi finish.
Very nice job.
Allen Neighbors
>Thanks for posting this. Very informative.
Allen
Gil Jones
>Nice looking pen!
Thanks for the info.
Stephen Mushinski
>Bart very interesting post. I do have one concern, and that is about scratches. Does this present a problem at all with the finish? Very nice pen by the way!- Steve
Hooligan
>Nice job, and it looks good. Though that seems an awful lot of steps for a finish.
Bart Leetch
>It takes about 5 minutes or less.
Jim Shaver Oakville, Ont.
>Nice Pen Bart!
Take care,
Jim
Hooligan
>I understand, Bart, and don't get me wrong. My finish process, is about a minute, minute and a half. When I turn pens, and have orders, often I have thirty or forty to do. I want speed, and efficiency, as much as a good finish. 5 minutes on each would destroy my timeline like no other.
Terry Miller
>To answer the question about scratches it is a very durable finish. It will hold up as well as the CA finish and takes a lot less time to complete.
Bart Leetch
>Hooligan
You need to remember I just turned & finished my first pen & it took me less the 1/2 hour start to finish. You could probably speed up the finishing quite a bit. I wanted something durable to start & didn't want to fuss around with this or that finish to find one & I knew Plexi Glass was a durable product & figures I'd give it a try. When & if I go into production I don't want pens coming back because of a un-durable finish.
