Total novice questions
woodburnbob
>I'm hoping someone might be kind enough to help me with some information.
I want to turn some handles...for chisels and files. Simple, no frills, utilitarian stuff. I could buy a wood lathe, I suppose, but I've got a South Bend 9" in the basement and a large 14X40 Logan in the garage (the lathe looking machine on the right in the picture). I'd prefer not to encrust them in shavings and sawdust, but I think I can cover them and clean them in less time and money than going shopping for a dedicated mini-lathe.
Any cautions you can think of?
Can you suggest an on-line site than might show me the basics of adapting something for a tool rest, what minimal tooling I need to do the cutting and the basics of safe tool technique? I just don't need any more books. I've got lots of chisels and gouges and can grind and hone well. I'd just like to adapt something rather than go out and buy dedicated turning cutters.
Also, would it be a mistake to try using a scrub plane against a rotating rectangular wood blank to rough down to a quasi-cylinder shape.
Don't hesitate to tell me what's stupid or dangerous, I have thick skin on these questions.
Thanks in advance, Bob
Re: Total novice questions
eliot d
>Wow, you're ahead of me. But, if what you have is a metal lathe, why not turn metal handles? Many wood turners prefer metal handles. Or, to avoid wood chips, what about some other material like plastic or Corian?
Peter Hyde
>Well a few tool handles certainly ain't gonna do much harm to those guys! Use the shop vac in the background. For a tool rest clamp a piece of 3/4" pipe or rod in the tool holder and adjust it so you are cutting just above center. Tools? Sharpen an old screwdriver or use a firmer chisel or even take a wood rasp to it. You can turn handles on a drill press or even just spinning in a hand held drill. Cutting metal in a wood environment is way more a no no than wood in a metal environment. We have this fight at work all the time after someone drills steel on the wood drill press!
Bill Crommett
>Just use your normal metal cutters and finish up with the scrub plane or a wood rasp followed by sandpaper. It would help with your chucking if you start with a wood dowl stock.
Re: Total novice questions *LINK*
Ken Grunke from SW WI
>WARNING: You are about to be bitten by the Woodturning Bug. Run out the door immediately and buy the best wood lathe and gouges you can afford, this will save you weeks or even years of trials and tribulations that all novices go through when buying inadequate equipment. And you will have the happiest cat in the world, with his or her huge litterbox right on the shop floor.
Seriously, Bob, if you want to go the simplest route, take a look at Darrell's post from Saturday on Oland tools. Take a machinist's square HSS bit, grind it to a round profile with a bevel of 45-55 degrees and stick it in the end of a big dowel or broom handle.
For a tool rest, a short piece of angle iron bolted to the cross slide with the edge at about center or a bit above ought to work OK. It should be as close to the work as possible. The top edge should be smooth and nick-free.
You'll probably start with square stock, I assume? Cut the corners off if you can, with a hand plane, spokeshave, chisel, or whatever. And you have a 4-jaw chuck to hold it with? Allow a couple inches extra length for the chuck, mount the wood in it somewhat centered and use a live center in the tailstock. A speed of around 5-600 rpm is good to start with, you can go higher as you gain confidence.
Darrell's site goes into using the Oland tool pretty good so I won't go into that. It's a very versatile tool, and good for a novice lacking other tools.
If you actually do get bitten by the bug, seek out an AAW chapter in your area, or find a woodturner somewhere for a mentor if you can. A list of chapters can be found at the link below. It's good to have someone personally guide you on the basics, I was not so lucky when I started in the late 80's. Good luck, and be careful.
American Association of Woodturners home
Leo Van Der Loo
Leo Van Der Loo
>Hi Bob
Bob I turn wood on a metal lathe, but have made tools and parts to do this for that.
But you can certainly make tool handles with what you have, first of, to round down the square stock, take a short piece of pipe that fits your wood or is slightly smaller, cut a slit in one side and hammer the wood into that, now you can use your self centering chuck and the wood is centered, mark the other end from corner to corner to get the centre point on that end of the wood, bring your tail stock up with a live centre in it, and take a small washer and put that on the center point so that the wood will not be split when you drive the point into the wood and only a small bit of the center goes into the wood,
Now for the cutting tool, take a piece of tool steel and grind a channel lengthwise alongside the top leading edge and grind the side for some clearance and to sharpen the tools edge, clamp your cutting tool in the regular manner, go to your highest speed, shut the lathe's automatic feed off, and hand crank the tool carriage, watch out for the wood likes to climb up on the tool if you take to big a bite.
After you have the wood down to the mayor dimension you can use a scraper to bring in the form you want and the cut the end to the ferrule size, rasp and sandpaper can also be used to shape and smooth the handles, and you can drill while still in the lathe the tang hole.
Also a link to my lathe if interested.
Have fun and take care
Leo Van Der Loo
http://homepage.mac.com/l.vanderloo/PhotoAlbum25.html
Barry Turner
>You CAN DO most anything you set your mind to, but it may not be worth the trouble in the long run. You can build a boat out of concrete, but there are better ways to get there. like using wood. In my opinion, turning wood on a metal lathe is one of these kinds of things.
Buy yourself a good mini lathe like a Jet or a Delta. It will just make you life simpler and you can concentrate on the task at hand instead of how to turn wood on a metal lathe. Although a lathe is basically a lathe regardless of the material it is intended to work, the differences in design are there for a reason. Buy yourself a set of tools, a good DVD on basic woodturning and you are off.
Forget using a scrub plane for roughing stock in the lathe. It won't work worth crap and may even be dangerous. Don't ask me how I know this. Trust me.
<You can build a boat out of concrete, but there are better ways to get there.
Ever hear of Ferrocement boats?
Re; Total novice questions
Mike Nelson
>Bob, this might be too simple an answere but here goes. If you need "simple, no frills" handles, go to the nearest Lowes or HD and buy a 1"X3ft dowel the wood of your choice, for a couple bucks, oak would probably be best. Take em home, cut em 6" long, drill a hole in one end slightly smaller than the tennon on the tool, add a little glue and smack em on what ever that thing is in the middle of your garrage and your in bussiness! Handles all the same size and no 'crust' on...that thing. You also save yourself from the joy and frustration of the woodturning bug! Hope this helps, Mike ;^)
Leo Van Der Loo
Leo Van Der Loo
>Hi Barry
Hope your wooden boat does not run into a concrete one, you might have to start swimming.
As for metal lathes turning wood, I started turning wood just about 50 years ago, and I do know that there are very few wood lathes that I would prefer over a good metal lath to turn some larger pieces of wood on, and yes I have a Delta mini lathe, my 3000 lb setup is just not as portable, however if it was, I would not need a mini lathe, You know I can turn very small but also very large wood on my metal turning lathe, and then change material and spin some metal, turn wood, copper, brass, aluminum or steel, well maybe it compares to a concrete boat in your opinion, I think you will be hard pressed to be able to handle some of that on your stubby.
Leo Van Der Loo
http://homepage.mac.com/l.vanderloo/PhotoAlbum28.html
Thanks for the help
woodburnbob
>Between the links from Ken and Leo, and the other responses, especially the Oland tool link from Saturday, I think I have what I need to muddle my way through.
I did try a few little experiments: chucked a 1.5" X 1.5" X 12" stick of white oak into a three jaw, pushed in a live center, and ground a stock metal bit with a lower cutting rake. I set a pretty big depth of cut (so there were no interruptions in cut) and used the auto longitudinal feet at moderately fast, just to see what would happen. The rectangular stick became a nice cylinder in one pass! Nices curled end-grain "chips". No disasters, threatening noises, fire or flying objects.
So I then put a 3/4" bar of drill rod in boring bar hole on the tool post and fooled with some free-handing, using wood-carving chisels and gouges. Quite a bit of fun. I see why some of you become addicts.
I think I'll now try making some real handles. I'm thinking the best wood I can get in town might be boxwood and beech. The former is expensive here and the later is cheap. Any thoughts on good smooth tool handle woods?
This is the sort of thing I have in mind:
Re: Thanks for the help
Cyril Griesbach
>And another one bites the dust.
Now go back and re-read the first part of Ken't post.
Leo Van Der Loo
Leo Van Der Loo
>Hi Bob
GoodGoing
As for the wood to use, I find beech rather short grained and not the best choice for longer handles, ash, hickory and hop-hornbeam are good as are black or honey locust for longer handles, and for short file handles almost any close grained hardwoods wood do, just be aware of the splintery type woods, and even those could be used after a dip in some glue or with an epoxy wipe on.
Leo Van Der Loo
