First hollow form, need advise
keith zimmerman, Normal IL
>I'm just completing my first hollow form and was wondering how others finish the bottom on these things. I do not have a vacuum chuck, so that is not an option. I've been leaning toward using a jamb chuck, but was wondering if there was a better way to do it.
Any advice would be well received and appreciated.
keithz
Re: First hollow form, need advise
Carole Valentine
>Hi Keith,
Many times I don't reverse chuck at all...just take it right on down and part it off, being sure I hold the parting tool at an angle so the base is slightly concave. I then use a bit or a chizel in my rotary tool to take off the nub and sand it. If I don't have enough wood to do that, I just chuck a piece of poplar or something and turn a cone to fit the opening, slip a piece of that rubber waffle mat stuff over the cone, bring the tailstock up and finish it up. Unless you have a vac chuck or some other means to hold the piece without the tailstock in the way, you are always going to have to do a little hand work on the bottom.
Donut Chuck *LINK*
Stuart Johnson
>Do a google search using donut chuck and you will come up with several hits. The attached (scroll down a bit) is a nice one but a little more complicated than some.
http://www.turnedwood.com/tools&jigs.html
Re: First hollow form, need advise *LINK*
Art Liestman
>I use a home-made doughnut chuck to do the bottoms of hollow forms. My article describing how to make one can be found online in several places such as Woodturning Online - see link below.
Woodturning Online Articles
Gil Jones
>I like my DIY Donut Chuck for finishing bottoms and such.
If you want better pics, I will email them. I am now working on a vacuum chuck, but I think the Donut Chuck may be faster to set-up.
Gil
Darrell
>Keith, I have tried the donut chucks and such and they work well but they seem to be more work than necessary, now that I have made a couple. I just go with a method similr to Carole's suggestion. Put the piece between centers and turn off the bottom. You can see it better here .
Around the Woods
Andy DiPietro
Re: need advise, The Kirsten Cone *LINK*
Andy DiPietro
>Kim Blatt wrote a procedure on how to make a Kirsten Cone. He lists the part #'s from mscdirect.com. I just ordered all the parts except the Nylon. You can save money by making the cone out of wood.
Click on the link then Newsletters, then September 2006 Newsletter and the go to page 3 The Kirsten Cone.
Have fun
http://www.keystonewoodturners.com/
