Speaking of chainsaws, electric, that is
W.C. Turner
>Do you have to drain the bar oil out of all electric saws, when they are not in use?
w.c.
Re: Speaking of chainsaws, electric, that is
GaryG in MD
>I have a Craftsman 16" -- I don't drain it, and it doesn't leak. ...Gary
Brian Hahn in SW Wisconsin
>I never drain the bar oil from my chainsaws, electric or gas. Just be prepared for the slow leakage of oil.
Re: Speaking of chainsaws, electric, that is *LINK*
Darrell
>There is no need to drain the bar oil out of a chainsaw, electric or otherwise. It is not in the engine per se and is really a reservoir of lubricant. However, clean the shavings from around the cog that drives the chain. If you have been cutting length wise through the log you can get long shavings that wrap around the cog and gum up the works. Oil from the bar oiler can soak through this like a sponge. It sort of wicks the reservoir dry. It will also make a mess under the saw as the oil seeps.
Around the Woods
Reason I ask.....
W.C. Turner
>is a friend just got a Remington electric, and the manual said to drain the oil out of the tank, when not in use, to prevent seepage. I don't drain the oil from my gas Husky, & had never heard of draining oil from gas or electric. I have thought about getting an electric CS from time to time, but, never had.
Oh, another thing, that came as a surprise to me. It said to use SAE 30wt motor oil. I would have thought the electrics would use the same bar oil as a gas saw. Has anybody heard of this before?
POO-lans don't leak...
BubbaBob
>...but I don't think they make an electric...just REAL chainsaws...LOL.
BubbaBob
Reason why...
Peter Teubel
>I had a few of those Remmingtons. The oil pump was a plunger type mechanism driven from a pawl on the drive sprocket. If the sprocket came to rest in that one spot where the pawl contacted the plunger, it would leave the tube open and the all oil would drain out (making a mess). Don't ask me how I know...
My Stihl 180E doesn't leak any oil.
My Stihl doesn't leak either - not a drop!
Carole Valentine
Because...
Peter Teubel
>This is only a supposition here concerning gas saws:
I would think the pawl (or cam lobe) on the gas saws are positioned on the sprocket where they only contact the oil plunger when the cylinder is at top-dead-center. Since that is at max compression, the piston could NOT land there after shutdown due to the pressure. Therefore, the oil pump plunger would never be left in the "open" position.
Hey, BubbaBob, glad you are still out there..
Don Henthorn
And alive, too !
Bill Crommett
Re: POO-lans don't leak...
Gil Jones
>My electric, 16" lime green, Poo-lan leaks bar oil big time.
Of course, it is not rusty.
Barry Turner
>Sounds like a little-known design feature to me.............
Dinyar Chavda
>I have a Craftsman that I bought used, and it leaks out completely--I don't know why.
On a related subject, I have an Echo that I inherited that does not leak, but it does not oil the bar either, no matter how much I adjust the oiling screw!
Any sugestions?
But the Poolan works!
But, the bar oil..
W.C. Turner
>So, you electric saw owners, what kind of oil do you use for the bar lube?
SAE motor oil, or the standard, bar oil, that is used for gas saws????
Re: But, the bar oil..
>Use what the saw's manual recommends. My Makita electric wants standard bar oil, just like gas saws. But the Remington (defunct) wanted 30W motor oil - don't know why and it ran OK with standard bar oil.
>My understanding is that some of these saws don't have a pump mechanism at all. The oils justs drips onto the bar. Thus when left alone, it will just drip onto the floor. I always used bar oil in mine, who reads the book. I had a Remington and now have a Craftsman that appears to have been made by Remington. Actually, Because it drools, I put very Little oil in it occasionally. I cut mostly green bowl blanks and am depending on the water in the wood to lube the process. I bought the extended warranty and am treating the saw as a disposable. The last one certainly was.
Re: And my old green Poo-lan.....
Jamie Donaldson
>.... electric leaked oil until it broke!!
Gil Jones
>I use regular bar oil, which is probably well filtered, used automobile oil(??).
Re: POO-lans don't leak; Mine, too, Gil.
Ruth Niles
Bill Crommett
>To avoid the mess of the oil all over the shop, I just run my Remington
DRY. Sure it wears things out, but it beats cleaning up the mess. And i only use it inside to trim the corners off the rounds that aren't round yet.
Bill Crommett.....
W.C. Turner
>Bill, Do you use 30wt. motor oil, or standard bar oil for gas saws?
Re: Bill Crommett.....
Bill Crommett
>In my gas saws , whether Stihl, Echo or Poulan, I use only Stihl bar and chain oil. On my electric Remington I use nothing but air.
Barry Turner
>With all that oil, I'll bet it didn't rust!
