question on milwaukee 0375 drill
jared
>I just bought another milwaukee 0375 to sand with. It is a factory rebuilt sold by a factory authorized dealer with warrenty on Ebay. Anyway, my old drill was reversed by a small slide switch on the main body. The one I just got is reversed by a mechanism on the butt end of the drill that you pull in and out and I think is an older model. The picture in the listing was clearly of the drill with the slide switch. Now the question is, is one type superior to the other? Is it worth trying to return or exchange it or should I just keep it and use it? Any thoughts on this? Thanks Jared
Re: question on milwaukee 0375 drill
ok now, trouble later
TDaniel
>Jared, the switch on the rear is no longer available so when it goes out you toss the drill. The smaller slide switch on top is the current model and parts are available for it.
Re: ok now, trouble later
eliot d
>I have a Milwaukee, which I bought used for about $110. But, believe it or not, you can buy pretty much the same thing from HF for $29.95. I use them both more or less interchangeably, and the HF works just fine. For the price how can you go wrong? (No affiliation with HF.)
For what it's worth, I also bought a cordless hammer drill for the same ridiculously low price from HF, and it' perfectly fine. I use it to screw in face plates into end grain with sheet metal screws. It's the perfect tool for that.
Darryl Hansen
>jared as TD mentioned the one you received is the older (very) unit. If the switch goes out you will not be able to find a replacement for it since the mechanism is no longer available at any of the parts suppliers I have checked with. I would send it back and ask for the latest model myself since you will be asking for future problems and frustrations.
