Re: My Latest Segmented Vase
Mkauder, Phenix City, AL
>Tom,
Nicely done. You joinery is good, joint alignment is good, nice wood selection, and feature/design ring is good.
As you progress, when you design a feature ring, try and construct is so that all the wood has the same grain alignment as rest of the bowl. Contrary grain direction can cause problems over time as the wood moves. 45 degrees to the bowl grain is certainly not as bad as 90 degrees. The one exception is you can usually get away with veneers or wood less than 1/8th of an inch thick.
After I don't know how many years I have been doing segmenting, 7-8 or more, I am still working toward that 100%. Both of Kurt Theobald's videos are worth the look - the second deals with the design rings.
Keep up the good work
Mark
