Another chainsaw q: rollertip seizing
Ken Grunke from SW WI
>The rollertip on the bar of my Stihl Miniboss 180C has been seizing on me. I've been able to work it loose with penetrating spray and tapping it around with a screwdriver/mallet but I'm wondering why this is happening!
I have no idea if oil is lubricating the rollertip, but the saw is using oil like it should. It seems to happen when I'm ripping small slabs of wood for turning blanks. I don't have a ripping chain, just the original factory chain. I get a thick buildup of long chips inside the cover and have to pull it off, clean it out, and free up the rollertip to get a couple minutes more of cutting. I know the saw isn't made for this type of cutting, maybe I should get a ripping chain but I don't do this that often.
The warranty runs out the end of Sept. and I'll be calling them but I'm just wondering if anyone else has had the same problem?
Re: Another chainsaw q: rollertip seizing
Bill Crommett
>My Stihl has a small hole for prssure lubing the roller tip with grease, and I have a small pressure gun with a needle point to use for this purpose. Ask your dealer. Now maybe things have changed in the past twenty years, but that is why Stihls are the favorite of the thinking saw users.
Yup, they've changed...
Peter Teubel
>Today, Stihl recommends NOT lubing the roller tip. In fact, the bars I have don't even have a lube hole. They claim that the regular bar oil will lubricate the tip sufficiently.
That being said, I've made a couple mods to my saws to help with the clearing of the long shavings when ripping along the grain. On my 390, I removed the chain catcher. The only thing it did was catch the shavings. On my 180E, I trimmed away some of the cover to create a more open space to help clear the sprocket. On my 170, it tends to clog them most, but I just haven't made any changes yet.
In both cases, it is important to cut slow but keep the chain speed high. This allows the shavings to exit with more velocity and therefore clear the sprocket cover more efficiently. In addition, when the sprocket cover gets jammed with shavings, it blocks the oil hole, so you're chain will run hot.
George Van
>Hi Ken, I use a Husky 262, 4.8hp for my main saw. I do however have a Stihl 021 for limbing and small work. When I occasionally use that to rip I can have a similar problem. I have solved the problem by holding the saw at 45 degrees when I rip which produces smaller shaving. That combined with high rpm seem to do the trick with that saw. The Husky has little problem but that is a pro saw and the ejection chute is large. I do not grease the tip on the Stihl, I was told that if I start I must continue.
Wilford Bickel
>I had problems years ago with grease getting thick and dry in the tip of the blades so I switched to using an oil gun on the tip roller holes every time I use the saw. I've not had a failure since. Prior to this I had the grease and sap freeze up rollers and would soak the blade tips in mineral spirits overnight (make sure all of roller tip is covered). This usually cleaned them out and freed them up - then lubricate well before starting again.
Re: Ken- check to see if.....
JamieDonaldson
>... there is a deformed tooth on the roller. I have had similar problems with my small Stihl when I knocked the chain off while trimming shrubs. The chain will also get chewed up and damage the sprocket and bar on such occasions. Just file the high spots down until something needs replacing.
>I have a little grease gun from a previous saw years ago, but this model doesn't have a lube hole at the roller. I find it hard to see how the chain oil can be relied upon to get down where it makes a difference (towards the center of the sprocket), while the chain is zooming along at so many miles per hour and flinging the oil from the tip. This is really a mystery to me. But I'll take the suggestions offered here, angling my cuts more for ripping and not pushing so hard. Not very often when I need to do this, only when halving rounds and then the bandsaw can handle the rest. Jamie, I don't see a deformed tooth, and the sprocket is spinning freely now but if I push the saw a bit too hard, then it binds up. I've had the saw for just under a year, and used it quite a bit for limbing and felling small trees but never had this problem until last week.
Thanks, guys.
Hooligan
>My 088 did that to me, once. It just flat locked up, like there was no tomorrow. I started lubing it after that. The 44" bar is the only one that it has done it to me. When I questioned Stihl about it, they said that it "just happened" sometimes, and that the easiest way to deal with it was to pour a bit of bar and chain oil right on it, and run the saw a bit.......sounded ludicrous, but its worked.
My husqy 61 has a small pinhole to lube the tip, and it has never occurred.
Re: Another chainsaw q: rollertip seizing *LINK*
Darrell
>Ken
Without a grease hole, the tip sprocket still needs to be lubricated. My Stihl 25 uses grease, but to lubricate a small one use bar oil as a lubricant. It is supposed to work its way down as you cut but I could not prove it. put some on the tip when you fill the saw with gas, it is a good reminder. Then work the chain back and forth to get the oil down to the sprocket.
Around the Woods
>Thanks Darrel, I knew I saved that little spare oilcan for a reason!
