Indigo dyeing process- long
John Veerkamp
>Indigo is one of many anchient dyes. I was got into dyeing fibers ie wool, cotton and silk , because my wife is a fiber artist and one of her guild events was living history presentations. I went to one about 15 years ago and got intrigued by natural dyes. Been dyeing since.
Indigo is disolved in a strong alkaline(lye for me) and then the lye is neutralized by an acid. The indigo in solution is pale yellow green. The dye bath is slightly on the acidic side to keep the indigo from precipitating out of solution. The process after preparing the dye bath is simple. The fiber or wood is submerged in the dye water for several minutes and then removed. As the air hits the dye it oxidizes and turns blue. Very cool! To get a darker color like the HF successive dunkings are used.
The entire pieces were submerged/dyed and when dried the bottoms and inside or outside were re-turned to reveal the white maple again.
Re: Indigo dyeing process- long
Re: Thanks John. Appreciated.
Allen Neighbors
Carole Valentine
>Didn't they use to dissolve Indigo in urine? Or was that the purple dye that was indicative of Royalty? Is the Indigo you use synthetic?
Barbara Gill, Remlik VA
>Very interesting John. I always have to wonder how the process was first discovered.
John Veerkamp
>Yes Carole they used to use stale urine for the alkaline to disolve the pigment. I use natural indigo though synthetic is available also.
John
John Veerkamp
>Lots of apocrophal(sp?) stories about this. Since indigo is a plant one of the widespreaad ones is that a baby was laid to rest on a pile po partially decayed plants that happened to be indigo. The baby did what babies do and the rest is history.
John
