Veritas - Innovation in Tools
Chuck Compatibility...for Russ??
Jack Savona
>I'm ready to buy a new chuck for a second lathe and need to find out if any non-Nova chucks would also take my collection of Supernova jaws. I remember Russ once detailing all of the compatibilities between chucks and kick myself for not printing it off. On a WC search, I could not go back and find that posting (search only gows back till May '06)and I didn't see it in the Articles' section.
Anyone have that info? Or, Russ, do you remember which other chucks would be a compatible option for me?
Thanks in advance.
Jack Savona
Re: Chuck Compatibility...for Russ??
What's Wrong With Nova ? ? ?
Barry Turner
>You have a bunch of Nova jaws, but you don't want a Nova chuck? You really ought to give the new Super Nova 2 a shot. I have one and I like it very much, so far. It takes all of the Super Nova jawsets with no problems.
Go to our "Messages Archive." Covers 5 years.
adrien
Re: Chuck Compatibility...for Russ?? *LINK*
DWR
>Jack,
Here is the chuck...
VersaChuck...
Peter Teubel
>Nova jaws fit all Nova chucks. They will also fit the Oneway Talon chuck, but you will loose the limit travel safety because the Nova jaws don't have a pin in one of the jaws on the underside. Conversly, the Talon jaws will fit the Nova line of chucks, but you will have to remove the pin from the Talon jaws.
Brad Vietje
Re: What's Wrong With Nova ? ? ?
Brad Vietje
>Jack,
Of course, there are a number of very good chucks out there, and each will have its fans and detractors. I will agree, however, that the S-N-2 is a very nice chuck -- much better than the original Supernova (which I own). The Titan is another option that will accept all your jaws, as well as a few sets available for larger work that will only fit the Titan.
I use a Stronghold on my Powermatic, and the Supernova on the smaller lathes, and both are pretty good. If you are moving into large work, many will swear that the Stronghold is the (only) way to go, but the Titan will probably work just as well, and allow you to use all your current jaws, too. There is an advantage to the shape of the Oneway Profile jaws (#2) when gripping square stock, or odd-shaped warped tenons, but that may not be worth the expense of getting an entirely different chuck system, especially if there are problems with jaw compatibility.
Safe spinning,
Brad Vietje
Newbury, VT
Archives
Jack Savona
>Thanks Adrien, I thought a 'Search' covered all those Archives. Now I know the Archives go past the 6 months of the Search. Found what I needed, right after Peter posted the answer.
Thanks again to all.
Jack
