We value your privacy.
>I was informed beneath an oak bowl I gave to a friend is an accumulation of fine sawdust indicating one or more beatles still reside in the piece. Is there a way to eliminate the beatles and put a stop to the carnage? Advice appreciated.
>Ken, I had a piece of maple that I microwaved to kill the borers. It worked on my piece (some fell out of the blank) and it has set in the shop for a year without further dust or signs of infestation. I believe the high moisture of the borers made them a perfect target for the microwave. I would assume it would work on a completed bowl also. Others may have experience in that area.
>I'm not at all sure about microwaving a finished bowl. I wonder if you nuked it hard enough to kill the bugs if it wouldn't ruin the finish or warp or crack the bowl.
You could try freezing the bowl, but I'm not all that sure it would be any less likely to damage the bowl than microwaving it.
Another thing you might try is to put the bowl in a plastic bag with some dry ice. A local grocery (Kroger) has dry ice and I picked up a pamphlet on it. One of the uses was killing mold and insects in grain. I did not research it, but I think it would permeate the grain with carbon dioxide and kill the insects by depriving them of oxygen. I don't know if this would sork, but if you could do it it would be nontoxic and would not needlessly stress it with either high or low temps.
You might be able to do it with toxic chemicals such as methyl bromide or Viacane, but they would be hard to come by and might damage the finish. They are the ones they use on powder post beetles in houses.
If you had a vacuum pump you could bag the bowl and draw a vacuum on it.
>150*F is the magic number. That is when the little buggers die. So depending on thickness of the finished bowl I would think 1 minute at high power and then leave it for about 10 minutes and then another 1 minute would do the trick. The surface of the bowl will probably only get to be warm to the touch so the finish should be safe. Or work it backwards and leave the bowl in until the outside is really warm but not hot enough to do damage. Note how long it took and do it again when the bowl has completely cooled down.I did this with a couple of spalted wormy maple mushrooms finished with shellac/oil and the finish was untouched.
>I have had good luck with denatured alcohol. Put about 6 ounces DNA in a glass bowl with the work and seal them in a plastic bag and let stand 48 hours. Do not soak the work in alcohol all you need is the fumes. This should be safe for all finishes except maybe shellac.
>Locate the hole. With a syringe, squirt it full of mineral spirits, or denatured alcohol. Listerine mouthwash will work, also; it's non-toxic to most of us, but the larva can't handle it. :o)
I'd probably not use the alcohol if it's a shellac finish. I don't know if it would damage it or not.
That's what I did (Mineral Spirits) to a shelf with worms in it. On unfinished pieces, I use lacquer thinner.
>Ken : You live where there is plenty of sunshine, so try the sealed plastic bag in the sunshine. Any thing in the bright sun wrapped in a plastic bag will get hot enough to cook all bugs.
