Have a question? Ask Woody!
Problems reverse chucking
eliot d
>I just turned a river -rock -shape hollow form to a fairly thin thickness -- about 3/16 in. -- maybe even 1/8. The wood is ambrosia maple, about 3 in high and 8 in wide. It was held on a glue block, which, in turn was held in a chuck. But when it came to reverse chucking it, to get the glue block off and clean up the foot, I had problems because the piece was very thin and vibrated. The wood just didn't want to be cut and there was a distinct hollow sound. I had the feeling that I was going to lose the piece. Leaving the glue block at the headstock end and parting off at that end gave me an even less confident feeling because I was fearful that it would go flying and really end up like potato chips. The vessel was too thin to use a live center cone (part way into the opening ) at the tail stock for support. I finally succeeded in the reverse chuck mode ,but it was harrowing, What should I have done?
Re: Problems reverse chucking
GaryG in MD
>Eliot,
What you want is a Kirsten Kone. The San Diego Woodturners site www.sdwoodturning.com, where you could get info and buy them, doesn't seem to be working right now for some reason. Basically, it's a special jam chuck to hold hollow forms straight while putting most of the pressure on the inside bottom above the foot where you are working. It was covered on Page 15 of the May 2002 issue of More Woodturning.
Art Liestman demo'd the concept to us in a CAW meeting on 5/14/05. Perhaps you were there. You can easily make one yourself.
This was discussed on WC on May 21, 2005 under the subject "How to reverse chuck a hollow form?" begun by Bill MacLachlan -- you can look it up in the WC Archives. A photo was posted in that chain on May 24 by Joe Flemming.
You can also see it at David Reed Smith's site:
www.davidreedsmith.com/Articles/WoodenFaceplate/WoodenFaceplates.htm
Scroll all the way to the last part -- Figs. 24 and 25.
This should solve your problem. ...Gary
>Eliot I turn a wooden mandrel that has 2 tenons. The smaller tenon extends far enough to touch the bottom of the vessel. The bigger tenon fits snug inside the hole of the vessel. I put 220 grit sandpaper on the end of the small tenon. Then I use the tailstock to put pressure on the waste wood on the bottom of the vessel. This way you can turn all of the bottom except a very small cone. If I need to turn the whole bottom I'll turn a small flange on the mandrel and tape the bowl to this flange and/or the faceplate. Then I can remove the tailstock for the final few cuts. Don't have a photo of this because I turn them as I need them out of green wood and just toss them afterwords.
ebd
ebd
>What I do is leave the waste block in the chuck. Part it off about half way, more if I feel confident, less if I don't. Then I use a back saw or dovetail saw to cut the rest of the way through. I clean up any waste that's left either on a belt sander or a full sheet of sandpaper glued to a sheet of plate glass (extremely flat).
eliot d
>I have one. but the hole I hollowed through is too small. ( Well, it is with the wood/rubber foot on it. I just went to the shop to look, and , sure enough the metal rod would have fit. All I had to do was turn a smaller foot. --DUH! I'm often so dumb, I can't believe it!)
eliot d
>Yes, yes; same idea as the Kirsten Cone. Why is everyone so much smarter than I am?
eliot d
>Yes that would work. But I think I prefer the idea of grabbing it by putting a mandrel through the hole, down to the bottom and bringing up the tail stock to grab the other side of the bottom, as suggested in the last two responses. I like to have a bit of a concave shape at the bottom. Thanks for your help. Your way could be the only way if the hole were so small that the mandrel would not be strong enough.
>Elliot, I have "Dicky the Stick" in honor of an old Johny Carson skit. Its a stick I turned from a scrap of Osage Orange. It has a number two Morse taper on one end and small hole in the other. Sometimes I leave a nib in the bottom of the HF on purpose (yeah right!) to fit in the hole. Usually I put a piece of cheap carpet pad in the HF for friction. I slide the HF over Dicky and if the stick is too small, I use blue tape to enlarge it to fit the mouth of the HF. Then I bring up the tail stock. I don't usually use glue blocks, but find that if I mount the blank with the "bottom" toward the tail stock and cut a chuck foot I have the Tail stock center mark. Then I reverse it into the chuck. This leaves the tail stock mark in the base and that's how I center on Dicky. BTW, don't forget to fish the piece of carpet pad out of the HF.
Bill Hale / Woodspinner
>I have 15 or so different pieces I use for this type of remount. Even thjough I never use a glue block the method is the same.
My fixtures are made of scrap wood with a tennon on one end. Each time I use them I re true if required. Insert the fixture through the hole and against the bottom of the hollow form. For larger forms I use a a kitchen hot pad inside and on small like yours I use nothing. Slide it in, lightly bring up the tail stock and do a slight back and forth rotation to center the fixture inside and tighten up lightly. If the bowl does not have a flat inside bottom try to match the fixture shape. Rember to maintain most of the pressure inside on the center and not the walls of the form. The walls only maintain the straight line of the form to the lathe headstock. Lightly turn away the glue block and sand off the center tip that is left.
Good turning and be safe.
Bill in Casa Grande, AZ.
