lathe
lathe
lathe
Mel Reed
>Hi All,First post here.Can any one tell about a Sears Roebuck and CO. Lathe?I know it is old it has a 1/3HP motor,#1morris taper,5 step pully,all cast iron,5in swing and 36"spindel length.The head taper is stuck.I don't know how to remove it.
Thanks Mel Reed
Re: lathe
Re: lathe
Steve Mushinski
>Mel,
If it is old and has not been use for a long time it is likely that the Morse tapper is kind of rusted tight. You can try a few different things but the only thing that I think will work is to use a drift and pound it out. Find a long enough piece of steel dowel to go thought the head stock and hit it will a hammer. You might have to hit it very hard. Remember safely glass! I know what it is like to have a chunk of steel in my eye from using a hammer in this manner.
Another thing would be to use a thin penetrating oil but I would think you would need to soak the hole end for it to do anything.
Good Luck!
Re: lathe
Re: lathe
>I agree with Steve. Put penetrating oil on it for a day or so. After you squirt it tap on the drive center lightly. The vibrations seem to help the oil penetrate. After a few days you should be able to drive it out. Sometimes putting a wrench on the drive center and twisting while someone else tries to knock it out will help. I prefer not to use the twisting motion alone it would be too easy to damage the morse taper.
Re: lathe
Re: lathe
Bill Howatt
>I would avoid twisting if at all possible. After the light taps to do the vibrating, when you go to drive it out, give it a good hard whack. A hard whack is much better than a million moderate whacks.
Bill
Re: lathe
Re: lathe
Barry Turner
>You might want to nose around this website. It has a lot of info on old Craftsman machinery.
http://www.lathes.co.uk/craftsmanwood/page3.html
