Re: General 260 opinions, value?
Bill Howatt
>I can't really answer your value question or make an informed comment on General's mechanical VS system other than in the school where we hold our club meetings there are 3 lathes like the one you describe and they are always working.
I have a General 26020, 20" swing, with the electronic variable-speed and if I were to do what I consider an upgrade it would only be to something in the price range of a Oneway. My General costs about half of what the equivalent size Oneway costs. I have no intention of upgrading and see my General as being the last lathe I buy.
I agree the design is dated but it is very robust where it counts. It doesn't have the rotating headstock capability and this can be nice for making bowls but the headstock always stays in good alignment. Since on my 20" machine the bed is low relative to the spindle, I don't find "bending over" the bed when necessary to be much of a problem but I'm sure others would differ.
If you plan on putting in the riser blocks you are going to have to factor in the costs of making your banjo(s) the right height unless it is included in the kit. I can't recall if the swing is a bit larger when turning outboard . You might consider setting it up to turn bowls outboard so you don't have any bed to get in the way at all. Be aware that the outboard spindle thread is 1-1/8", LH whereas the inboard is 1-1/4" RH, so you need to have the appropriate chuck adapters or faceplates depending if you are inboard or outboard. It sounds like you may have this stuff in the package. Does it include the outboard bed piece?
It would be fairly easy to change the motor and install a Variable-Frequency Drive controller to have electronic variable speed in the future. Naturally, it will cost a few hundred to do this!
Not sure about you cabinet comment on turning bowls, I find the headstock is usually the culprit when I am trying to get behind something and I consider the General's headstock to be better than many in terms of size for this problem.
Hope this helps a little,
Bill
