finish bees wax, shellac mix
Greg Mitchell
>I am going to mix some bees wax, tung oil and linseed oil, and I was thinking (some time a bad thing), could I mix in shellac flakes to make this mix more durable. will this work? thank you, Greg.
Greg Mitchell
Re: finish bees wax, shellac mix
W.C. Turner
>Take a look at the menu, on the left of the MB, & click on Russ's Corner. He's already covered this. Good info.
W.C.
Russ Fairfield
>The short answer is that you can mix any combination of finishes and it might stick on the wood, and it might even "dry" if given enough time. But just because you can do it doesn't mean that you should.
The beeswax added to any of the finishes will act as a plasticiser and make the cured finish softer than it would have been had it not been there. This is often done as a top coat to give a more satin feel to the surface of an oil finish, but only in small amounts like 1-ounce of beeswax per quart of finish. Adding wax to shellac will yield a soft finish that is easilly damaged by moisture.
Tung Oil and Linseed Oil are both a reactive finish that changes from a liquid to a solid by polymerization where the liquid molecules link together to form the larger molecules of the solid. The thinners are turpentine and petroleum distillates such as Mineral Spirits, naptha, and kerosene. They can be mixed together and often are.
However Shellac is an evaporative finish that forms when the solvent evaporates and leaves the solids behind. The thinner is Denatured Alcohol. The last time I looked, shellac and the oils didn't mix. Neither does alcohol and the Mineral Spirits.
Greg Mitchell
>Thank you Russ. Just a thought.Greg
