We value your privacy.
>I purchased a used jet 1236 that appears to be in fine condition; the price was right and I couldn't turn it down. However, I know little about turning apart from this forum and a couple of books I've read.
The lathe did not come with the faceplate. I have not decided what I am going to do with this lathe, but small bowls and boxes are probably in the future. Should I buy a replacement factory faceplate or would there be something nicer (and probably pricier) that would give me more bang for my buck in the future? Details and model numbers would be most helpful.
Thanks for any advice in advance. If there is something fundamental that I have missed or left out, kindly point it out to me. Thanks, Stephen
>Steve:; Mine came with a 6" faceplate and have not used it yet in four years. You will most likely be using 2" and 3" faceplates. I wouldn't buy the 6" untill you really need it.
>a 6" faceplate on a 12" lathe is not what you want. A 3" faceplate is the largest that your lathe will ever need. One-way makes a nice hefty one for it. Other things: take a one day beginners course before doing anything else. Don't buy a lot of tools. Get a 3/8" or a 1/2" bowl gouge with a deep "U" shaped flute, (sorby or One-way) and the cheap set of HSS tools from Harbor Freight and a good grinder, preferably 1800 rpm x 8" and a jig to sharpen the bowl gouge and you are all set. If you like turning your current lathe will not last long as you will want to upgrade but the other tools and grinder will be around for a long time so buy good ones.
>Stephen, Nick is right. For that size lathe, you'll probably want to get a 3". I have a 4" Oneway faceplate and I use it all the time, but I wish I had a smaller one. I have a 6" faceplate that I don't use at all.
Just get a faceplate that will thread onto your spindle. And remember, you get what you pay for. A true-spinning faceplate is better than a cheaper one that has a bunch of runout.
I have used a 1236 for a couple years and find it to be quite adequate for most "small" work. I have made bowls, vases, platters, etc., and never used a faceplate. I don't like them, and IMHO there is no reason to use one.
I start pieces between centers and put a tenon on the bottom. I then reverse and hold the tenon in an inexpensive chuck. For finishing the bottom I reverse again on an appropriate jam chuck made out of PVC or a scrap of wood. End of story. Don't waste your money on a faceplate -- put that money into an inexpensive Grizzly chuck. It will be more than adequate for your work. When you need more, you'll know it.
You don't have to spend a lot of money on tools. Benjamin's Best tools are inexpensive and more than adequate. In addition to the gouges, I would also recommend a nice heavy round-nose scraper -- the 1.5" Benjamin's Best is quite suitable. A good sharpening system is critical -- you want to make it so that you ENJOY sharpening, not resist it. I like my Wolverine system and Vari-Grind attachment for sharpening gouges. They are easy and fun to use and worth the money.
Safety is critically important. There are only two 'times' when you are turning -- before the accident and after the accident. Bad things happen literally in the blink of an eye. Find a Club nearby if you can. Driving an hour each way is well worth the time spent. If you can, get a mentor, and get all the dangerous tool angles out of your system before you actually try them. DAMHIK.
Keep your tool rest CLOSE to the work piece. ALWAYS wear a full face shield. Good lighting is often overlooked -- you have to be able to SEE what you are doing. etc., etc.
>Small face plates are nice. I'm going to be somewhat contrary though. I think a good chuck such as a Oneway Talon might be a good investment. You can turn the outside of bowls using the woodworm screw and get a nice tenon and then hollow out the inside. They are more expensive, but are a good investment. Of course, you can always get both.
>For a variety of face plates, (you don't have to go with the big brands) you'll need to know what is your spindle size (TPI). For ex: 1 1/4X8 or 1X8 for your jet. Then armed with this info you can look at sites and find 'generic' face plates. Try looking at woodworker.com for CNC aluminum faceplates. PLease take the advice of the others and enjoy a lesson. Turning is similar to golf. It's not like regular sports, (woodworking). It's a whole new game. It's real easy to get frustrated until you get it, and depending on the wood, can be quite expensive.
Welcome to the hobby, and congrats on getting your lathe. You made a good decision on the Jet 1236. Many of us started out with that model. I bought mine used, and it was used for many different projects for about four years. I easily sold it for the same amount that I paid for it. The resale value is very good, and they are in demand.
After a period of time, you will discover what you really enjoy doing, it might be bowls or platters or spindles or very small pieces, and then if you desire then you can move to a more specialized lathe. For some of us that means a much larger and heavier lathe, for others of us it means something smaller, such as a Jet mini lathe.
I have two faceplates, but I only use them to hold glue blocks. If you decide you need one, if I remember correctly, you will need one sized 1x8 for the spindle.
But step one is....... before you spend a bunch of money on anything.... is TAKE A CLASS. It is very difficult to learn this hobby by reading about it. Plus, the class will help you discover what types of projects will be fun for you.
>You could also buy a tap for your spindle threads, then you can make faceplates and lots of other usefull things from wood scraps. I think your 1236 is 1" x 8.
You can find a tap at mcmaster.com.
There are instructions on the net for making faceplates. Here is one for a screw chuck.
http://www.aroundthewoods.com/schuck.shtml
You could adapt this to faceplate, or use it as is.
The standard advice for a beginner who has access to a lathe is to seek out a local club, make some friends, and get the advice of a more experienced turner you can relate to (and hopefully turn wood with!). The AAW is found at www.woodturner.org, and has a listing of local and regional chapters around the USA and beyond.
As much as I have posted negative comments about MY 1236, its a great lathe to learn on, and for many all the lathe they'll even want/need. I wouldn't spend much on tooling until you have a feel for what you want to make with it. Safety warning: ditch the toolrest banjo extension -- bad design, not necessary, and dangerous piece of junk. One other thing: not all 1" x 8 TPI faceplates will fit the 1"-8 spindle properly. They need to thread all the way on and seat against the vertical shoulder on the spindle without extending through the faceplate and sticking out where the wood is fastened. If yoou get one, amke sure it fits properly before use, and exchange it if it doesn't.
I disagree with the view (not Terry's) that you should not buy a faceplate, though I completely agree that a decent chuck is easier and more versatile. A 3" faceplate won't cost much, and can be used in all sorts of waste-block chucking arrangements, and is better than a chuck for hollow forms in some cases. I also think its good to learn how to chuck things with a faceplate before moving to the convenience and luxury of a chuck -- not in a guilt-ridden penitence sort of way, but to force one to explore various jam chuck, friction chuck, glue block, and every-other-sorta wood-holding arrangement... This is because I've run into a few relative beginners that started off with a nice chuck who had NO CLUE how to reverse a piece to remove the foot, or how to think creatively about how to hold a piece on the lathe, because they couldn't see how to do it with their chuck. I also think a small faceplate is a good way to complete the lathe, so if it is outgrown, it has a complete set of stuff for resale.
>I have a 1236 and only used the 6' face plate that came with it with a donut chuck. On occasion I use a 3" plate and for the most part I feel one or two would be all that you would need..
IMO I think a chuck is a better option. Besides the link below I've seen some chucks for sale on ebay
I have hesitated to use or recommend a lever-operated chuck on lathes that don't have an easy-to-use spindle lock... Have you found that this chuck is easy to use on the 1236 ? I may very well be full of wax on this...;-)
>Brad, I'm not Ron but I'd like to offer my input on this--
1.) The 1236 spindle lock consists of the knockout bar, which goes into one of two holes into the headstock casting to fit into one of twelve index holes in the spindle. Not exactly convenient, but one can get used to it.
2.) I bought the Vicmarc 3 1/2" chuck with tommy bars in '99, and my other lathe, on which the chuck was used the most, had no spindle lock. It was usually not to difficult to find two holes on the chuck for the bars to be operated with one hand.
My advice to anyone looking for a first chuck, and where money is tight, to consider a tommy bar chuck--they're not that bad. And they are a little more compact, with less overhang on the spindle.
A lot of stuff can be turned with a small faceplate, spur center and pail center. I would get a 2" and a 3" faceplate. Too many lathes come with 6" or larger face plates and they never get used except as sanders if you put a sanding disk on the face plate :-) There are some project ideas here and I have some instruction and projects on my home page as well.
Congratulations! I remember when I was a newbie with a Jet 1236! I did some of my best work back then, and I sure had fun! I'm sure these great people have given you much better advice than I could proffer, but I will add to anything they have said: Have fun! Whatever else this is, it should always be fun!
>I've actually recommended tommy bar chucks to anyone with an easily-locked spindle, and know that many turners, like RR himself, prefer them. I concluded that holding the knockout bar in the little hole with my belly (though it will stay there without being held) while operating the chuck would be fairly cumbersome, but I'm glad to know that with a little practice, it works fine. I may get a tommy bar chuck for my new-to-me mini, leaving the Stronghold and the Supernova for the larger lathes.
