Brass Ferrule Making?
Tony - Memphis
>I've see a lot of folks use the brass compression nuts and flare fittings for ferrules. I'm going to give it a try. Any tips or links to old posts? What is the best way to knock off the corners of the hex? I have some ideas, but since I know some of you have been there / done that...
Thanks,
Tony
Re: Brass Ferrule Making?
Bob Fawcett
>I had some brass garden hose fittings at the house and used one of those as a ferule the other day. It is round, not hex, has a nice knurled grip area and the end is turned down in a taper. Made a great ferule just as it came. The inside was threaded for the hose connection. I just turned the handle to be a tight fit for the threads and threaded it onto the handle.
Look in hose repair section and the Depot or Lowes.
Norm Smith in Nova Scotia
>Wow Guys, That is a great idea.
Norm
>Tony I make lots of tools, in fact I have to make 7 pairs of hollowing tools for my upcoming class. I just use regular turning techniques with HSS tools. I like to rub the bevel and watch those little curls come off. some people like to use scrapers and that works also but on some metal will give you tearout just like wood. Try both methods and see what works for you. You will have to sharpen your tools more often, brass and copper tend to dull the tools.
Stuart Johnson
>Other than looks what is the advantage of knocking off the corners over just leaving them?
turning copper
Mike Nelson
>John, I bought a 3"x3" cylinder of copper to turn for a base and collar. What speed do you use? During a test the copper did not cut smooth, 'gummed up' using a 1/8 parting tool to true one end taking small cuts. Any suggestions? I'm thinking of rigging a pan under the piece to use oil/water flow while cutting. Ideas anybody?
Ric Taylor
Ric Taylor
>Tony,
I've handled brass and copper nuts just like they were wood. I use a regular bowl gouge to turn off the corners and make it round, then sandpaper to make it smooth and polished. It's easier than it looks.
Ric
Bill Howatt
>I've read that you can buy brass ferrules very cheaply at stores where they sell/assemble hydraulic hoses for farm and other equipment.
I just buy a length of copper water pipe of and cut them to length with my pipe-cutter. Bit of sanding on the edges and it's done. You can also just buy a straight coupling fitting.
Bill
Copper Pipe
Ron in Drums PA
>Just cut off a 1/2" or so from a 1/2" or 3/4" copper pipe and you have a ferrule.
nor reason other than wanting it round
Re: turning copper
>You shouldn't need water or oil coolant to cut the stuff. you might try slowing the lathe speed down. If your scraping try shear scraping instead of leaving the scraper flat. If your cutting with the gouge slow your feed rate down. It's very easy to push the gouge too fast. j
One other problem that you can't do much about now, is some copper you find has been work hardened and is a little too hard. I haven't had this happen with brass yet. To anneal the copper you heat it red hot and quench it in water. This is the opposite of annealing steel. This softens it so it will cut better. If you've already glued it on the handle this isn't an option.
Chuck Engstrom
>Here's a shot of handles I've made using tubing fittings to make them quick-release handles. The ferrules are, L to R, a store-bought ferrule (Lee Valley, very inexpensive), copper pipe, and copper pipe cap drilled with top drilled out. The tubing fittings left and center started out with hex sections like the one at right, turned down to round with scraper or file (brass is easily worked with woodturning scrapers)
This has worked out pretty well, since I now have a bunch of different tools that will fit each handle. I had to split the compression ring on each of them to make them fit the tool shafts, which are not dimensioned aa exactly as standard tubing sizes (the middle handle has a double compression ring; it's an odd item I found in a surplus bin). Sizes here are 1/4, 1/2, and 5/8; I'm working on a 3/8 now.
Fog Tanner
>I make all my own tool handels and use copper pipe. I was cutting the pipe on my lathe with a skew and a parting tool. I used the skew to champher the ends and cut a groove for the parting tool to start.
But, my brother in-law had some slack time in his machine shop, so I bought two ten foot sections of copper pipe with different ID's. He cut them into lengths on his horizontial saw and cut them to 1" lengths and cleaned the ends up on his metal lathe. If I live long enough to use these up, I probably won't be able to turn handles by then. But, if I do and can - I'll have them, otherwise I'm taking them with me for the next life. Some of the small machine shops can do this kind of work as filler for a small price, and you too can have a lifetime supply.
Re: Copper Pipe
bob davis
>now u are talking !
Edward in Vancouver
>Made a couple of my own turning tool handles and used purchased brass ferrules, cheap, think less than a buck each. I turn the wood for a very tight fit, remove the handle from the lathe, heat the ferrule with a blow torch or over a gas stove burner, then hammer it on gently. When it cools, you'll get a very tight fit. Same thing for copper ferrules made from pipe.
Torchin', tappin', turnin'
Edward Damewood, Northern Alabama
>I'm a rookie turner at best, but I've successfully made some tool handles with improvised ferrules. I have used copper pipe and even some 1" steel tubing, though the latter was a bit of overkill. That steel ferrule does have a nice robust look on the oversized turning tool handle it's on, though.
I made sure the stock was good and dry and sized for an interference fit in the ferrule, put the ferrule down on a scrap 2x4, heated the ferrule with a MAPP torch*, and tapped the handle down into it. The 2x4 had a hole in it just the right size that it would stop the ferrule**, but allow the handle stock to go down into it -- so as to firmly seat the ferrule. Come to think of it, I even put a slight taper on the stock so as to encourage the ferrule to stay seated over time. Anyhow, it's tight as a tick, and I expect it will stay that way. Polished it up with a little sandpaper, and Bob's my uncle.
*Yeah, that scorched the 2x4, but what the heck.
**Come to think of it, there's a piece of ferrule material embedded in it for just the right size and strength needed.
Re: Copper Pipe
Barry Turner
>I like to use 1/2" and 3/4" copper couplings. The couplings are a bit heavier than copper pipe. Only problem is they are too long. You can usually get two ferrules from each coupling.
This is what I used
Bob Fawcett
>I used the outside threaded piece from a hose repair like in the picture.
Re: Copper Pipe
Ron in Drums PA
>I've used them also, I cut them down to make 2 or 3 ferules.
Wow, great info! Thanks!
Tony - Memphis
>Lots of good stuff here. Thanks very much!
I've used some copper pipe and the ferrules from Lee Valley adn those worked fine. I like the look of the copper with certain woods. I am anxious to try some of these new ideas (new to me anyway). Guess i'll be making all kind of stuff! Might try making a couple of tiny bead scrapers too. I made one of those tools I saw in Woodturning Design to make mini coves. It works really well.
Thanks for the help.
Tony
