We value your privacy.
>For the Powermatic 3520A , what are the pros and cons of setting the belt at the low speed setting or the high speed setting? I have mine set high, figuring I can slow it way down with the variable speed control, and I can get maximum speed should I want it. But then, what's the purpose of the slow speed setting?
>Is the torque a function of the pulley setting or the actual rotating rpm -- independent of the pulley setting? Assuming that there is more torque at the low speed pulley setting -- for the same actual rpm, would one put this into practice by roughing out at the low speed pulley setting? I have not had any trouble roughing out on the high speed pulley setting, for example, I mean, sometimes it's rough and bumpy, but the lathe has never come close to stalling out or even slowing down. I guess I'm asking how to put the physics to practical use.
>Try coring a bowl on high speed and you will imediately know why there is a low speed. Also needed when roughing large (over 17 inch) out of round blanks.
>Now I get it. It's like driving a car up a hill in low gear vs. high gear. If the hill is steep enough , you'll need the low gear. I've been getting away with it because I don't core anything nor turn that large.
I should have known better: the pulley is larger on the low speed setting. Since torque is force times pulley radius, the torque is greater -- at the same speed. I should think before I ask dumb questions!
>Heat. Running the motor at lower speeds tends to draw more current and generates more heat in the windings of the motor. The slower motor speed also means that the fan cooling the motor is running a a slower speed, moving less air. This isn't likely to be much of an issue for you. If you were to regularly run the lathe at 100 RPM, using the high speed pully, you would put unecessary stress on the motor.
>eliot I just don't turn at high rpm's even on small stuff. I leave the belt on the low speed setting. The motor runs faster at this setting when you are using really low speeds so the fan in the motor keeps it cooler. As you've probably seen I've been turning incredibly thin things lately and you would think I'd need really high rpm. the highest speed on the low belt setting has been just fine.
>You also get finer control of low speeds on the low speed setting. The speed control works by varying the frequency of the AC feed to the motor. If the pulley ratio is 2 to 1 for low speed and 1 to 1 for high, then 0-60 hertz will give the same speed range with the low speed pulley as 0-30 hertz on the high speed.
The high speed pulley would give finer control at the top of the range. 200-400 hertz vs 300-400 hertz for example.
>I have had my PM for 7 or so years. It is so old, that it has a little fan under the baffel on the back to keep the converter from over heating. When I first started doing bigger bowls (in the 12 inch diameter plus range) on it, it would trip the breaker every time I turned it off or slowed it down rapidly. I eventually figured out that it was because I was in the high speed range, and with the mass of the wood, and the electronic brake, it was too much. Now I turn all bowls on the slow speed range, and all spindles and boxes on the high speed range. I could turn some of the smaller bowls at speeds in excess of the 1500 rpm range, but I would have to stop and change the belt way to often.
I have a VS General which also has a 4-step pulley. I like having the belt on the low-speed setting for roughing, not only for the better torque, but it keeps the speed from accidently being set way too high for a new unbalanced blank.
>Eliot, you're helping out a lot of us dummies. When a question is asked like this one, someone will always come out with the mathematical answer. I knew about the torque, but I didn't know why. Now I do.
>I don't think there are any dummies on this board -- certainly not you. It turned (no pun) out that if anyone was the "dummy" , it was me for not thinking through the torque aspect.
