Shopsmith 10ER
Shopsmith 10ER
Shopsmith 10ER
Tom O'Connor
>Is anyone using a Shopsmith 10ER for turning. If so is there anything I should know before starting. Thanks in advance. Tom
Re: Shopsmith 10ER
Re: Shopsmith 10ER
Ed Heuslein
>Howdy Tom: I started out on a 10-ES. Make sure your headstock and tailstock line up. You can do this by putting a spur center in the headstock and a live center (I advise against using the dead center that comes with the lathe) in the tailstock and bring them up together, almost touching. The tailstock side is the adjustment in this case. Also, I switched to a "link" type belt which improved vibration, which is somewhat of a problem with this unit also. You're limited to the diameter of the turnings, but that's not all bad. When you get proficient on the Shopsmith it will be time to upgrade anyway. Happy turning. Ed
Re: Shopsmith 10ER
Re: Shopsmith 10ER
DD
>Not sure about the 10ER, but watch out for the speed. The slowest my shopmith would go was 500 rpm. It made my intro to bowl turning a lot more interesting when turning unbalanced loads. Had sand bags all over the place to stop it from walking around the shop. Just make sure your piece is relatively balanced before you start.
DD
Re: Shopsmith 10ER
Re: Shopsmith 10ER
Tom O'Connor
>Thanks a lot, very helpful information. Tom
Re: Shopsmith 10ER
Re: Shopsmith 10ER
Ed
>The caution from DD doesn't tell you the half of it - the news is worse. My 10ER, and I expect they're all the same, has a triple-step pulley on the motor and shaft. The best you can do is to cut the motor speed in half, to about 850 RPM. Very thrilling at times. I WISH I could slow it down to 500. That's actually the biggest problem with the lathe. Well, that and getting the toolrest to stay put sometimes....
