Rolly Munro Mini Hollower set *LINK*
Ed Moore
>I have recently been in touch with Rolly about his Mini Hollower set and my check is on the way to New Zealand.
1. Binh Pho apparently has the Mini Hollower set available.
2. Packard may soon carry Rolly's line.
3. Rolly says that he uses the tool to hollow boxes quite often and that it does a good job.
4. I believe that Rolly has updated his e-mail address on his website.
Ed
Rolly Munro website
Re: Rolly Munro Mini Hollower set *LINK*
Ric Taylor
I'm Confused
Ric Taylor
>Ed,
Rolly's website doesn't say anything about mini-hollowing tools, it just mentions regular tools. Where is the information about the mini tools?
Ric
Re: I'm Confused
Gil Jones on Lake Seminole Georgia
>I had the same thought(??) No pics, no price; zip.
Confused - not your fault *LINK*
Ed Moore
>Ric,
I was persistent, someone posted the correct e-mail address and Rolly answered my e-mail. If you want some product info, please look at Carroll's website in Australia. The sharpening jig is only good for the larger sized cutters, not the minis.
Rolly sent me info in an e-mail and in the last post he mentioned Binh Pho and Packard. Rolly is going to Europe in September so there may be a disconnect for awhile.
Ed
Carroll's Woodcraft
Confused - currency
Ed Moore
>Folks,
Carroll's website posts Australian dollars, and one AU$ is about $.757 US$. At least it was a few days ago.
And if you consider New Zealand dollars, one NZ$ is about .636 US$.
Rolly initially sent me a NZ$ price list. Then he sent me a US$ pricelist from when the exchange rate was less favorable. We eventually agreed on a US$ amount and I immediately sent off a check for that amount. As a former mathematics professor, in my little world numerical inconsistencies cannot be left unfixed. ;^D
So, think about where the website is before assuming that $ means US$.
Ed
eliot d
>I clicked on the link and got into the tool part. No problem. But the tools have an 1/8 in diameter shaft. Is that extremely small? I get vibration with 3/8 in shafts.
Re: I'm Confused
Mike Nelson
>His web site needs updating! But I emailed him and got prices, ordered the 5/8 shaft with articulating link and 'mini cutter head. I wanted the heavier shaft and he told me the mini head was easier to use and got inside tight shoulders. I also ordered an extra carbide cutter he says is for hard dry wood, we'll see.
It is difficult to order from Munro, there is no order form, you have to email to get prices, convert the prices to US, add shipping then mail a check or fax with CC#! DO NOT send a fax unless you can afford the price $16.00 in my case from TX, I just happened to ask the operator while trying to figure out codes etc. I ended up sending the order email using a scrambled method, put junk (%,$,& etc) between your credit card #'s. He says it will be here in ten days or less. His prices are less than Carols or any in the US and shipping is only a little more. Hope all this helps. Email- rolsbols@ihug.co.nz
Mike Nelson
>Eliot, noticed that too, I believe it is a mistake and he means 5/8, what I see is 1/2 and 5/8 shafts. Mike
article in the new Woodturning
David Galloway
>There is a fine article in the new issue of Woodturning on the Rolly regular tool. Check it out.
W.C. Turner
>Sounds like way too much trouble to place an order.
