Belt tension PM 3520
Mike Nelson
>The other day I caught the back of my left hand between the tool rest and a large un-hollowed vase while removing front tenon, the belts squealed and the vase stopped. I got a 'rasberry' on the back of my hand and a little soreness for a few days but nothing major. Anybody else loosen the belts slightly on the PM? I also found that occasional catches don't destroy the piece or throw it across the room!
Re: Belt tension PM 3520
Re: Belt tension PM 3520 *LINK*
Jerry Hall
>I keep mine just a tad loose. If you go to the link and look under "maintenance - belt tension" you might find some useful discussion
AAW Forums - Powermatic 3520 Tips
Brad Vietje
Re: Belt tension & Reset
Brad Vietje
>Mike,
Glad you got no more than a raspberry ! I keep mine a little slack too, for my safety and that of the more delicate pieces on the lathe. I've only had to tighten it up when coring big blanks and/or burls, when it can scream like a Banshee if too loose. It's probably better for the longevity of the motor to leave the belt a little loose, especially when using the lower speed range -- that pulley is pretty far out on a long shaft, and can put some real force on the motor bearings.
BTW: in case you should have a monster catch, the electronics are set to stall (at least on the B model), and the motor will wind down without any electronic breaking, which can be really embarassing when demonstrating how a catch develops inside a bowl, and you pwoduce a whopper, and then the lathe won't run. From what I gather, this is the only time you'll need to fuss with the little motor controller box -- there's a red reset/stop button, and a green start button that are pushed in that order to restart the lathe.
Safe spinning,
Brad Vietje
Newbury, VT
Bob Fawcett
>Brad,
I had one similar catch. I only had to turn off the lathe and turn back on. Maybe mine was not the same.
My 3520 is the B model also.
