Dust collector
Dust collector
Dust collector
Bill Crommett
>Does anyone have a clue as to how I can keep the upper bag on my 2 HP Grizzly dust collector.. The problem stems from when I modified the system to accommodate a 6 in PVC inlet which seems to allow the system to overwhelm the bag attachements. I have sprayed spray glue all around where the friction band is attached, I have also used the notorious all purpose stuff called DUCT TAPE to try to hold the bag to the metal frame. Today I just looked, and there is the bag on the floor of the paint locker again. Fortunately the system is placed out in the paint locker and not in my shop, but it sure makes a mess of the paint locker. HELP !
Re: Dust collector
Re: Dust collector
Bill Hale / Woodspinner
>Bill
If you don't live in the city just vent the whole thing out doors, no bags. My vent has about 15 ft of flex pipe on it and is not to loud.
Bill in Dolores, CO
Re: Dust collector
Re: Dust collector
georgetroy
>You could try a band clamp made from metal or rubber. Perhaps a rope tourniquet, get the loops close stick a bar in there, twist and tie down. GT
Re: Dust collector
Re: Dust collector
Peter Hyde
>I would think adhesive backed velcro strips would work on the metal rim and maybe sewn on the bag itself.
Peter
Visit my site at:
http://www.oldtoolsshop.com/Galoots/pHyde/
Re: Dust collector
Re: Dust collector
Peter Teubel
>If a metal band clamp isn't holding it, its time to get a bigger (and better...shaker felt for example) bag or a cartridge filter (or 2).
Re: Dust collector
Re: Dust collector
Bill Crommett
>All good suggestions, some better than others. Always looking for the easy way out, I think I will try to find some flex pipe to fit the discharge and vent it to the outside. If I turn on the sprinklers for a few minutes first It will keep most of the dust confined to the bushes and the neighbors won't complain
Not a perfect solution, but it fits my attitude at the present.
Thanks fellows.
Bill
Re: Dust collector
Re: Dust collector
Bart Leetch
>This is what I did. I purchased the big filter about 2 years ago & just got the 6" intake cover when I install it I'll also get or make a deeper chip container than a garbage can.
Re: Dust collector
Re: Dust collector
Walter Ahlgrim
>Be careful if you vent outdoors. If the building contains a furnace, water heater, fireplace you could reverse the flow in the flu pipe and start a fire or fill the building with carbon monoxide.
Walt
Re: Dust collector
Re: Dust collector
eaglesc
>I am not familiar with the fitting on the Grizzly but I know the one on the Delta is a little tough at times to keep on.
One relatively easy alteration you can make it to add an extension to the collar with sheet metal and flare that out.
The band clamp won't slide over that.
The collar could be pop riveted on and sealed with silicone from the inside.
HAve you checked the amp reading on the mot or after making the change to 6" pipe?
More air entering the suction could over heat the motor.(read burned out motor)
Re: Dust collector
Re: Dust collector
Bill Crommett
>No problem, Walt. The whole thing is in a paint locker attached to the shop with an independent door.
Re: Dust collector
Re: Dust collector
Bill Crommett
Re: Dust collector
Re: Dust collector
Bill Crommett
>Same jerk on the keyboard) A good point about the amperage, but after two years and a lot of heavy sucking, the motor is still running and has not over heated.
Re: Dust collector
Re: Dust collector
Bart Leetch
>Another thought put camper foam peel & stick tape on the bag rim & then put your bag over that & then the clamp band. I did this to be able to keep a regular heavy duty garbage bag clamped to my DC to be the lower catch bag.
