jamieson hollowing system
Kenny in Indep
>Hello, Looking for comments, pro and con, on the Jamieson Hollowing system. Thanks for your time and input.
Kenny in Indep
Re: jamieson hollowing system
eliot d
>I don't have that one; but I have three others: the Spin Doctor(Keith Clark), the Don Derry, and the Elbow. I could go on an on about their pros and cons. but that would be a very long post , and none is even the Jamieson. But if you're interested, please feel free to contact me.
Rick in Michigan
>I build my own two years ago and really like the control and the smooth easy control. the laser makes measering the wall thickness less time consuming. I thought I was missing the conectin with the wood so I build a hand held hollower and did not finnish the first vase and went back to the Jamieson system, and have never used the hand held rig agian. Hope this helps.
Brad Vietje
>I have a home-made knock off, and not the Jamieson. I got it because I was committed to making hollow forms, but had damaged my right elbow trying to over-muscle hand-held tools used incorrectly.
I like using it for larger HF's, but turn the small and medium ones hand-held -- partly because my system was built with larger diameter bars (since adapted to smaller sizes, too), but mostly because it feels more hand-made that way. The basic system of a stabilized boring bar is pretty slick, and adding the laser for thickness measuring was an inspired idea. These things are easy to use and easy to learn how to use, and while it won't eliminate occasional mistakes, it will help you create nice work rather soon without doing any physical damage to your body. BTW: once you learn the proper use of the hand-held tools, you are very unlikely to develop tendonitis or other problems, and I almost never cut through the side of a thin vessel.
If I were cranking out a large volume of hollow vessels, I'd probably use it more, though it somehow feels more satisfying to create even, thin walls with hand-held tools -- maybe like using a special plane to create a shaped molding instead of a router.
Safe spinning,
Brad Vietje
Newbury, VT
bob davis
>ibuilt my own also.myexperience is similar to ricks..invaluable for hollow forms
