Re: Recomendation on Club Video equipment
Mike Brazeau
>At the Golden Horseshoe Woodturners Guild in Burlington, Ontario, I was involved about four years ago in the first phase of upgrading our video from one TV and an old video camera. We implemented three of Woodchuckers minicams in addition to a roam-around camera and went to two TV's. All was routed through the Woodchuckers Switch Box into a VHS recorder and out to the displays over coax and channel 3. That was a major step to build on.
Our current setup uses a Panasonic Digital camera with image stabiliazation (was about $600 cdn) and usually two of Woodchuckers Minicams with the switch box. One is overhead the lathe and another usally aimed from as you face the lathe the left side and slightly behind the turner. Sometimes we aim one at a flip chart if the demonstrator is sketching. Lighting can be a major bugaboo. You need enough for the turner to work, but video cameras don't like bright objects in a dark background.
In the spring we added and an Epsom Video Projector and a rear projection screen (was not expensive). An old stereo serves as the audio sytem, but will likely be upgraded. The screen is hung from the T-bars of the suspended ceiling and is working out really well. No one walks through the light beam . Only negative is that if you are connecting a laptop for Powerpoint etc. you need long cables or a wireless remote for mouse control etc. to keep the speaker in front of the crowd.
Currently we make both a VHS copy of the demo (including all switched cameras) and a DVD made from the digital video camera. The image stabilization feature is not one I would overlook. The four foot image of a zoomed stabilized image is incredible. I call videoing a curse and a blessing at the same time. It takes a lot of work to get working smoothly and one person must accept responsibility. Setup can run an hour easily. Acceptance by the membership is overwhelming and that makes it worthwhile. We have 100-120 at an average meeting. At the GHWG, one member has put everything into a carrying case prewired to simplify setup. It took us almost four years of struggles reminiscent of the posts about videoing at Louisville, to get to that point. Don't get discouraged.
If anyone wants more technical details of models etc. I can dig them up.
Mike
