My band saw hums - guess if forgot the words
Steven
>When I turned on my 30 year old Craftsman band saw the motor just hummed. When I gave the motor a spin by hand and THEN turned on the switch while the motor was still moving (making sure my hand was well clear) it started up just fine. Any ideas what the problem could be? Thanks in advance
Re: My band saw hums - guess if forgot the words
Start Capacitor?
Clem Wixted, Jonesboro, AR
>Steven,
There could be a starting capacitor that gives the motor a kick to get started or it could be a set of contacts that energize the start windings.
Check around or under the motor for a round cylinder about 1-1/2" dia by about 3 or 4 inches long. If you have one it likely is the culprit. Easily replaced. Some old Sears motors have a flat rectangluar capacitor that fits between the motor mount and the motor.
If you don't have one then it may be a set of contacts inside of the motor housing that pull in when the motor is started and then when it gets up to speed the contacts kick out and the motor keeps running. Try some low to medium pressure air to blow out any dust or debris around the ends of the inside of motor that may be keeping the contacts from touching.
Hope this helps.
Clem
don lewonczyk
>Make sure the motor is turning when you blow out the motor with low PSI or it won't help to much. Don L
Dave Belser
>From my own limited experience and knowledge:
If you blow a starting cap the motor may still start but more slowly. This has happened with my dust collector. Right now I'm stil using it even though the starting cap blew, being careful not to start/stop it a lot.
The start winding switch on my table saw used to get cloged/stuck. When you fliped the switch it would just hum. If I could manage to flip the switch while the blade was spining, it would sometimes start. Blowing the dust out cleared the problem up several times until it didn't :(
It was actually not that expensive to have the motor fixed at a local shop.
Your problem sounds more like the centrifugal start switch
- Dave
