Hey! Carol Valentine
Dave Anderson (PacNW)
>Woodcraft has a sale on a Senco (top brand) Compressor and Brad nailer combo For $189.00 Enter cuopon code 99101 and get an extra $15.00 off. Promo # is 145770P This compressor should be just the ticket for you (WWW.woodcraft.com)
Good Luck,
Dave Anderson
Re: Hey! Carol Valentine
Less than 1cfm at 100PSI...
Peter Teubel
>I have 2 of those compressors. They are fine for a pin nailer or SMALL brad nailer, but that's it. It's little 1 gallon tank takes minutes to fill and empties in a few seconds when trying to blow shavings/dust away.
Carole Valentine
>Thanks, Dave, but I think I need a little more air than that and don't need the brad nailer at all.
Re: Hey! Carol Valentine *LINK*
Hooligan
>Carol here's a great compressor, and the price is right. I have this model, actually three of this model, and they have not failed me in daily use.
I don't know what your intended use is, but it will run air tools, small grinder, air sanding equipment with no problem. It will cycle a bit more with the Sander, but everything else treats it just fine. Mine will keep up with six roofing nailers with no problem.
The buy it now is VERY right, as I paid about $215 for mine from where I got them. Even with shipping, you are pretty right.
*Disclaimer, I am not, nor do I know of the seller. I simply looked on Ebay, for an EC-12, knowing that they are often there for a reasonable price, though not usually THIS reasonable*
Compressor
