Broken Drain Valve on Compressor
Jennifer@Indy.USA
>Hi gang,
Does anybody know if these things are a standard size? The one on my Porter Cable compressor is broken. The "wings" of the valve that you turn to open and close it...just spins! So I can't drain the thing. It's a very poorly designed valve. I went to Lowes to see if they have a replacement but the rack was empty....apparently I'm not the only one with this issue. I guess I'll have to use ViseGrips to remove the plug.
Any help would be fantastic.
Thanks,
Jen
Re: Broken Drain Valve on Compressor
Steve Mushinski
>Yes the are Jennifer. Any kind of plumbing store should carry what we called a butterfly value. Not sure which size you have as it is measured as pipe thread. If I had to guess I would think it would be 1/4 inch. Pipe is measured using the inside opening so the fitting will look larger than 1/4", do to the wall thickness. Your best bet is to take it out and take it with you to the store. Just below the wings is a brass nut. It will have been sealed in with pipe cement so it will be hard to turn at first then will just thread out. Hope this answers your question.
Bill Grumbine (Kutztown PA)
>Hi Jen
You should be able to find the parts you need in the brass fitting section of the home center or plumbing supply store like Steve mentions. I went just a little farther when I needed to replace mine a few years ago. I could not fit my big fat hand under the compressor to get the thing turned, and it was always a fight. Going on a post from someone else (this is all the way back before the end of BP), I added a length of high pressure tubing and a valve on the end. Now I have a tail of tubing sticking out from the compressor. Not only does it give me a little bit of a reservoir for water to accumulate before starting to rust the tank, it makes it a lot easier to open and drain.
Bill
Jim Shaver Oakville, Ont.
>Hi Jen,
Well that just sounds aweful! I can't really help much, I use a large truck inner tube myself, so the only valve I worry about is the one in the hand pump I use to fill it up!
kidding of course...
Good luck with the fix,
take care,
Jim
Scott Hogsten
>I'll second Bill's suggestion, if the drain valve is easier to get to you are more likely to drain the tank.
Scott
Steve Mushinski
>Funny Bill, mine is just about the same except I just used a short piece of hose. I forgot about it until you mentioned it. Good advice Jennifer. - Steve
>Jen,
Depending upon the size of your compressor, that drain valve will be either 1/4" or 3/8" NPTM thread. The drain valves used by most manufacturers are notorious pos and should, IMO, be replaced before use. Do not, however try to replace it with the same thing. Use a Stilson pipe wrench to carefully remove the old valve fitting (after you turn off/unplug the thing and depressurize the tank!! ). You can take the old valve with you to the borg to match the thread size. When there, look for a 1/4-turn ball valve with the same size thread in brass.
If your tank drain is hard to get to, you can install a "street" "L" fitting in the same thread size and then pipe the drain out from under the tank where you then install your valve. As suggested, makes things much easier.
If, however, you'd like to dispense with having to drain your tank, you can use a pressure-actuated auto-drain valve which will automatically drain the condensate from your tank by a short-burst vent when there is a 10psi drop in pressure. The auto-drain valve usually costs about $50. I installed one on my IR 60 gal compressor and it has worked perfectly over the past 5 years, and I don't have to worry about draining the tank or rust.
m
Auto-Drain Valve
>If interested in the auto drain valve, go to McMaster Carr's site and input Part No. 4919K13 in the search box. Current price there is $58. Grainger used to have it for less, but I haven't seen it on their site for a while. Not worth it for a small compressor only used occasionally but cheap for most anything 30 gal. or more and used.
mm
Bill Hale / woodspinner
>Jennifer
I did mine the lazy way. I put an ell fitting, a nipple and a quick connect fitting, like you for the air hose, on the bottom of the tank. All I do is connect the air hose and blow off to the outside.
Bill in AZ.
Re: Auto-Drain Valve
Ken DeMarco
>Jennifer,
for a better deal try harbor frieght auto drain valve part number 46960 $16. I usually dont buy anything at harbor freight but have been using this one for a couple of years without problem
Ken DeMarco
There was.....
W.C. Turner
>somebody that used to have a tutorial, including pics, on how to install the extra tubing, not sure if it was the automatic one or not, but, he told everything that was needed for the installation. Can't remember if it was back at BP, or if it was here. Can't remember his name now, either, but, he included a photo of himself in his posts. He always wore a white hat, like the old time southern gamblers used to wear on the Riverboats.
Does any of this ring a bell with any of ya'll?
Thanks,
W.C.
>Ken, best check that number. I ran it on the HF site and it returned nada, but a search came up with 46960-7VGA. Is that the same one you have? If so, is that tubing presurized? Since it's only rated at 100psi, most small(er) compressors running today top out between 120 and 175 psi, would likely rupture that line before long. I also noted that it will not fit machines having drains larger than 1/4" NPT thread without getting extra fittings and adapters. What is the petcock for on yours. My Wilkerson is completely automatic, but has a small manual bypass ball valve built into the housing.
Re: There was.....
Jennifer@Indy.USA
>WC, I'm drawing a blank on that one? Although I have the Badger Pond archives on CD....I could do a search on it...or start from the archives here that Ellis Keeps from Badger Pond. Once I get digging through there I might as well take the day off... It would be like going through old photo albums! Memories....
Thanks,
Jen
Thanks one and all!
Jennifer@Indy.USA
>Much appreciated advice. I think I'll try to tackle the hose extension route. I don't drain my tank nearly enough and the hose would certainly make it easier to do more frequently. I never attempt to drain it without pulling it out from the wall and literally laying on the concrete floor in order to see any lurking spiders. I'm not sticking my hand under there without checking first, NO WAY! The hose would relieve a lot of spider anxiety while draining :)
Hee-hee,
Jen
Re: Lowe's has all you need.
Al Crandall (NE of Indy)
>Last year I removed a broken petcock from my compressor tank and replaced it with a brass 90 fitting and a 3" brass pipe nipple. I screwed a chrome plated ball valve on the the nipple so that it is easy to drain and the drain handle is outside the tank for easy access. All items came from the plumbing aisle at Lowe's.
Jennifer@Indy.USA
>Graci` Al! I'll drop by there and get what I need.
Jen
Hey Al Crandall!!
>EPA hasn't come a'knockin whining about crossing state lines, permits, and such trivia, so how's the glow-in-the-dark stuff doing?
M
**** Interesting Info From H F Manual
Clem Wixted, Jonesboro, AR
>This is taken fron the on-line manual for the bleeder.
Tubing 8� 1/4�, 250 PSIG Polyurethane (145 PSI Working Pressure)
Note: The Drainer Kit is designed to be used on compressors that have poly nylon �unloader� tubing and not with compressors with �unloader� tubing made Copper or Aluminum.
Note: In order to use the Compressor Drainer Kit with compressors that use a "Pilot Valve�, parts that are not included with this kit may need to be purchased.
