We value your privacy.
>Newbie question... I just bought a new tool rest (Delta) for a lathe I picked up. The tool rest is rough and makes it difficult to slide the tool along the rest. Is this intentional or should I file and clean up the tool rest surface?
>Dressing your tool rest is a regular maintainence task. A bump or nick that causes your tool stick will mess up your smooth cuts. I use a file and emory paper to polish my rest.
>..... out nice and flat, rub a candle along it and rub down with your hand - the tools will gliiiide and not leave rings on the wood for every spot that the tool hit a nick.!
>Clean it up. Do the job Delta filed to do. Draw filing, that is holding the file perpendicular to the rest, while pulling or pushing it lengthwise, will do the job. Was that clear as mud?
>Be sure to round over the sharp edge that faces the turning...you don't want to get a finger caught between that sharp edge and the turning. The more highly polished the rest, the easier the tools will glide....the tools can be polished as well. Skew chisels especially benefit from this, as the sharp edges of the traditional skews will dig into the rest.
the base of the banjo can be polished and the edges eased to make the whole thing slide easier on the ways....
>Its not a bad idea to round off the sharp corners mentioned on the skew. Look at your tools and consider "softening" or rounding any of the corners than might ride on the rest. It took me a while to screw up the courage to grind the corners off my nice pretty tools, but it really made a difference. They slide well and don't knick the rest any more, when I get (extraordinarily rare) catches.
PS, a 100% foolproof method of avoid catches is, Don't turn the lathe on. Nothing else is so effective as having the workpiece sitting perfectly still.
